  • SN95 4.6L Mustang Tech
Fuel Filter change?
  • Thread starter Thread starter X-L-R-8
  • Start date Start date Mar 10, 2006
X-L-R-8
11
  • Mar 10, 2006
Hey guys.......Where is the fuel filter located on an 02 GT? Can I change it myself? I'm not much of a mechanic......If so, what brand do I get? Anything I need to know before I attempt this? Thanks!!!!!
the98stang
2,408
Clovis, CA
Mar 10, 2006
  • Mar 10, 2006
The fuel filter is located behind the gas tank up top. It almost looks like a soda can. You can do it yourself. Just wear goggles and watch out for spewing gas. Don't worry about a specific brand. Just goto Napa and they'll have it. You'll also need a special tool from Napa (or other special tool stores). It is used to disconnect the fuel lines from the fuel filter.
Buy a Haynes repair manual book. It has step by step instructions on how to do this. The book is $15 and you will use it time and time again. Good luck
Nater
239
Maplewood, MN
Mar 10, 2006
  • Mar 10, 2006
It's right in front of the fuel tank. Relieve the fuel pressure by removing the fuel pump relay/fuse or by triggering the fuel pump shut-off in the trunk. Start the car and let it die or crank it over a few times. Any brand but Fram is fine--I'd go with Ford. You'll also need a special tool that you can get from Autozone to remove the filter.
Block up the rear, put a rag around the hose you are going to remove, take off all the clamps and remove the hose. Make sure you are not directly under since fuel will drip. Installation is reverse and pretty easy.
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Mar 10, 2006
  • Mar 10, 2006
Here ya go...
http://bullittarchive.com/1009.htm
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 10, 2006
  • Mar 10, 2006
E
exindust
329
Moorpark, CA
Mar 10, 2006
  • Mar 10, 2006
Kilgore is sad coz someone beat him to the bullittarchive link.
D
danny04GT
50
Phoenix
Mar 10, 2006
  • Mar 10, 2006
Make sure you dont drop the cap for the Schrader valve. Took me 20 mins to change the Fuel filter. Took me twice as long to find the cap in the engine bay and get it out.
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
D
Is this a fuel filter?
  • Dutch74
  • Oct 2, 2025
1974 - 1978 Mustang II Talk & Tech Oct 21, 2025
welder4956
