  • SN95 4.6L Mustang Tech
fuel filter on 98?
  • Thread starter Thread starter 98gtblue
  • Start date Start date Feb 16, 2004
98gtblue
237
houston
Feb 16, 2004
  • Feb 16, 2004
where is the fuel filter located on my 98 mustang gt? Really need to change it.
thank you
70stangcoupe
2,895
Winston-Salem, NC
Feb 16, 2004
  • Feb 16, 2004
Right in front of your gas tank. Crawl underneathe the back, and look up. You'll see a cute round thing that almost looks like a pop can. Break out your manual and follow the steps.
I was going to change mine myself, but I sissied out and paid the shop to do it when they changed my oil.
98gtblue
237
houston
Feb 16, 2004
  • Feb 16, 2004
thanks i really appreciate it.
98LazerGT
47
San Diego
Feb 16, 2004
  • Feb 16, 2004
Make sure you have the plastic fuel filter remover quick disconnect tool thing. I'm not sure what it's called but trying to get the fuel filter off without it is an exercise in futility at best.
98gtblue
237
houston
Feb 16, 2004
  • Feb 16, 2004
thanks i will try and get one.
Wil
581
Burke, VA
Feb 16, 2004
  • Feb 16, 2004
Do not pay to get it changed, it is the easiest thing to do and it only take about 10 mins if you have the quick disconnect tool ( If you don't, get one, if make life so much easier )
StangJonGT
1,329
Seattle
Feb 16, 2004
  • Feb 16, 2004
The tools come in sets for different sizes; they are called A/C and fuel line disconnect sets. The consist of plastic rings that you slip over the line and slide into the end of the fuel filter, releasing a spring lock on the inside.
Jon
athensoutkast
33
Ga
Feb 16, 2004
  • Feb 16, 2004
don't forget to depressurize the fuel system!
StangJonGT
1,329
Seattle
Feb 16, 2004
  • Feb 16, 2004
It isn't necessary to bleed the fuel pressure. I have never needed to, and I have done several. You can, if you wish, bleed off pressure through your shraeder valve on your fuel rail next to your manifold.
Jon
stangman
2,690
10
69
in a 3 bed, 2 bath
Feb 16, 2004
#10
  • Feb 16, 2004
  • #10
Jon
yeah it's no big deal, the fuel that comes out is very minimal. imo, not enough to go to the trouble of bleeding the shraeder valve
D
drizztkun
497
Montreal Quebec
Feb 16, 2004
#11
  • Feb 16, 2004
  • #11
yeah never bleeded the valve either, just dont put your face underneath and keep the filter in a upward position, 10 min you should be done
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
dylan9075
D
M
New to group and looking for some insight
  • Mnolan
  • Mar 15, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 15, 2026
nickyb
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
