Fuel Fuel Gauge problem run down
Espo720
55
Fuel gauge is pegged past full, even when the key is off. Gauge didn’t work when I bought the car so I changed the sending unit when I did the fuel pump and filler neck seal. I’ve tried 2 other slosh modules and still pegged past full.
I’ve read about 40 different posts about fuel gauge problems and even the @jrichker Troubleshooting steps. Still stumped. I know the car needs a battery soon but that shouldn’t make the gauge not work.
Any ideas?
I just had a similar issue with my ‘86. The older cars need a sender with different resistance readings than the newer fox bodies.
They sent me a newer one and my gauge was reading E when it was full. Not sure what the opposite would do if you had one for the older foxes (judging by the 140 speedo, it’s a later model)?.
If you take apart again, check the resistance readings at Full and Empty. If nothing else, you can know if it’s the right one or not.
I got a sender for 87-97, cars a 90. Resistance is correct for whats in the tank currently when I check it at the sending unit.
It would seem to me it is grounded someplace.
I was heading in that direction and kinda dreading it. Could I ground the sending unit in the rear of the car on its own and get away with it?
Also would cleaning the metal contacts lightly with scotchbrite kill the slosh? There was a grayish film on em so I cleaned em up. Wondering if that created some static and killed the module.
I'm far from a electronic expert but I used to test gauges by grounding the wire with the ignition on, if the gauge advanced to full the gauge was good but yours is already at the full side. That's why I say it is grounded, I would put the original slosh module back in and check the wires for a ground starting at the connection at the fuel tank, there should be a connection behind the bumper cover, check both directions,
Ran outta daylight but I was able to confirm the right signal coming from the sending unit up to the dash harness. Interesting enough, the damn gauge is reading completely opposite now way past empty. Seems to be a ground issue, I noticed some greening on the laminated plastic circuit right around the ground area. Do they sell these circuits to replace or is it a cluster thing?
Alright I took the cluster apart, popped the stepper motor out for the fuel gauge and ran jumpers for ignition, ground and signal. Stuck on Empty until I attach the signal jumper, then it shoots right past Full.
On the bench, I can't get any variation of ohms from the motor if I rotate the needle manually with my meter on the ground and signal probes. Safe to assume the gauge itself is no good?
Dropped the tank again and double checked that the sending unit is good, resistance is perfect. Started tracing the yellow/white wire up into the car and notice that resistance dies with the key on, thats at the plug under the driver side kick panel.
Also double checked at the tank, and resistance disappears when key is on. Currently the gauge sits at about 1/4 tank then drops to Empty with key on.
Measuring resistance on a an energized circuit will give unreliable results and may damage the meter.
Thanks for the heads up. Swapped Original slosh module in and it sits at about 3/4 when off and almost full when on, replacement shows a 1/4 tank off and empty on, last module I have just goes straight to empty. Strange....
Have you done the resistor test as mentioned below?
Fuel Quantity gauge troubleshooting 87-93 Mustangs
Revised 8-Apr-2017 to add warning about non-interchangeable fuel tank senders between 79-86 and 87-93 Mustangs.
The red/yellow wire (power supply to gauge & sender) should have 12 volts when the ignition is in the start or Run position.
Troubleshooting the gauge and sender circuit:
Since the sender uses a variable resistor, sum the resistor values of 22 Ohms (empty value) & 145 Ohms (full value). That gets you 167, which you divide by 2: that gets you 83.5. So in theory, 83.5 ohms is 1/2 full. A trip to Radio Shack for the closest combination of resistors to make 83.5 ohms gets you one 68 Ohm (Catalog #: 271-1106) + one 15 Ohm (Catalog #: 271-1102) for a total of 83 Ohms at the cost of $2 plus tax. Wire the resistors in series to make a resistor pack and cover it with heat shrink tubing or electrical tape. The 83 Ohms is close enough to the 83.5 Ohm figure that it shouldn't matter. Disconnect the electrical connector shown in the diagram for the tank sender unit. Connect one end of the resistor pack to the yellow/white wire on the body side fuel sender electrical connector and the other end of the resistor pack to ground. Make sure nothing is touching that isn't supposed to and turn the ignition switch to Run. If I am correct, the fuel gauge will read 1/2 full, or very close to it. If it does not, then the odds are that the gauge or anti-slosh unit are bad.
How and why the test works…
Most of the fuel gauge failures give a stuck on full or stuck on empty as a problem symptom. Using a resistor combination that mimics 1/2 tank allows you to decide if the gauge and anti-slosh module are the problem source.
If the gauge reads about 1/2 tank with the resistor combination, that points to the sender as being the culprit.
If the gauge reads full or empty with the resistor pack in place of the sender, then the gauge or anti-slosh module is at fault.
Fuel gauge sender testing and replacement
The next steps require dropping the fuel tank and removal of the fuel level sender. Here are some useful tips...
I have done the tank removal three times, and the main issues are getting the car up on jack stands and getting the gas out of the tank. DO NOT try to do this job without jack stands. Becoming a pancake is not part of the repair process.
Pumping out the old gas:
If the old pump still works, you can use it to pump the tank out.
1.) Separate the pressure line (the one with the Schrader valve on it) using the fuel line tools.
Look in the A/C repair section for the fuel line tools. They look like little plastic top hats. You will need the 1/2" & 5/8" ones. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling.
OR
View: https://www.youtube.com/watch?v=vRTjYAxvaCs
Use a piece of garden hose to run from the pressure line to your bucket or gas can. Make sure it is as leak proof as you can make it. Fire and explosion are not part of the repair process...
2.) Jumper the fuel pump test point to ground.
attachments\68357\
Turn the ignition switch to the Run position. the fuel pump will pump the tank almost dry unless the battery runs down first.
Some 5 gallon paint pails lined with garbage bags are good to hold the gas. The garbage bags provide a clean liner for the pails and keep the loose trash out of the gas so you can reuse it. If you decide to use a siphon, a piece of 1/2" garden hose stuck down the filler neck will siphon all but a gallon or so of the gas.
Remove the filler neck bolts and put them in a zip bag. Disconnect the supply & return lines by removing the plastic clips from the metal tubing. If you damage the clips, you can get new ones form the auto part store for just a few dollars. I have used tie-wraps, but that is not the best choice. Then you remove the two 9/16" nuts that hold the T bolts to the straps. Put the nuts in the zip bag with the filler bolts. Pull the plastic shield down and away from the tank. Once the tank drops a little bit you can disconnect the wiring for the pump & fuel quantity sender.
The fuel gauge sender assembly comes out by removing a large metal ring that unscrews from the tank. There is a separate mounting/access plate for the fuel pump and fuel gage. You are supposed to use a brass punch to tap on the ring so that you don't make sparks. Look closely at the rubber O ring gasket when you remove the fuel gauge sender.
When you install the metal ring that holds the sender in place, watch out for the gasket O ring. Some RTV may be helpful if the ring is not in excellent condition.
The tank to filler pipe seal is a large rubber grommet. Inspect it for hardening, tears and damage. At $20 from the Ford dealer, it might be a good idea to replace it.
I used a floor jack to help lift the tank back in place. You may find that it is the only time you really can make good use of a helper.
All resistance measurements should be made with the power off.
Note from bstrd86 - 86 and older fuel tank sender units are 73 ohms empty, 8-12 ohms full. The 87-93 fuel tank senders are of 22 Ohms empty & 145 Ohms full. The two different groups of sensors are not interchangeable
The yellow/white wire will show a voltage that varies with the movement of the float on the sender unit. To test the sender, set your Ohmmeter or DVM on low Ohms. Then disconnect the sender and connect the Ohmmeter or DVM to the yellow/white and black wires from the sender unit. Move the float arm while watching the Ohmmeter or DVM. You should see the reading change from 22 to 145 ohms +/- 10%.
If the Ohmmeter or DVM resistance readings are way off, replace the tank sender unit.
Use extreme caution if you do the next step. Fumes from the gas tank can easily ignite and cause a fire or explosion.
With the sender unit out of the tank and connected to the body wiring harness, turn the ignition switch to the Run position. Move the float arm and the fuel gauge indicator should move. If you are very careful, you can use a pair of safety pins inserted in the connector for the yellow/white and black wires to measure the voltage as you move the float arm. The voltage will change, but I have no specs for what it should be.
Do not short the safety pins together or to ground. If you do, you may damage the anti-slosh module or create a spark. A spark with the fuel tank open could cause a fire or an explosion.
If the voltage does not change and the tanks sender passed the resistance tests, the anti-slosh module or gauge is bad.
The 87-89 module is shown below.
This is what the 90-93 module looks like.
LRS has the 90-93 module as a standard catalog item, cost is about $160
Inexpensive anti-slosh module repair - should work on 87-93 anti-slosh modules
Copied from DrBob
I worked on an 88 Mustang today that had similar symptoms. Short version, I took the “anti slosh module” off of the back of the instrument cluster and replaced the electrolytic capacitor. Fixed it for $1.39 with a part from Radio Shack.
In an attempt to help other folks, here’s the long version.
Remove the “anti slosh module” located on the back of the instrument cluster. There was a single Torx screw holding mine to the cluster.
Find the electrolytic capacitor. It will be the largest, 2 wire component on the board. The capacitor may have a red or blue plastic wrapper on it. Mine was red.
The wrapper should have printing on it. Look for printing that looks something like this:
100uF+25V
The “100uF” tells you this is a 100 micro Farad capacitor. The “+25V” tells you the capacitor is rated for 25 Volts. Yours may be different. You may use a higher voltage part but don't use a lower rated voltage part. If you use a lower voltage part the capacitor might open later on down the road or it could be as bad as catching fire.
If you can’t find the printing you’ll need to remove the part. You have to anyway so nothing wasted. However pay close attention to the way the capacitor is oriented on the board.
One end of the capacitor will be bare metal with a wire sticking out. The other end should have some sort of insulation over it with a wire sticking out. The bare metal end is the negative end while the insulated end is the positive end. Pay attention to which end is connected to which hole on the board.
Get a replacement part. I got mine at Radio Shack, $1.39. Here’s the info:
100µF 35V 20% Axial-Lead Electrolytic Capacitor
Model: 272-1016 | Catalog #: 272-1016
See www.Digikey.com for better capacitors – these are rated for automotive use and 105° C temp which is needed to survive the hot environment found in automotive electrical circuits.
P/N 4215PHCT-ND $2.10
OR
P/N 4201PHCT-ND $2.59
Fuel tank sender unit:
Be sure to get the lock ring and a new seal if you order the tank sender unit.
Alrighty so at the end of the day I swapped the oil pressure gauge motor in for the fuel gauge motor. Apparently putting 12v straight to the motor wasn’t smart, they seemed to be the same except for different needle stops on the face so I swapped em.
With my original slosh module, I read just below full with key on and it drops to about 3/4 with key off. 2nd Slosh module reads 1/4 tank key off then drops to empty with key on. 3rd slosh module just reads empty.
If I swap gauge motors back, it reads full all the time. Still not sure this is correct, but I’m gonna run with it for a little and see how it plays out.
When I topped the tank off today after I thought it was working... Gas was leaking out of the sending unit seal, turns out the seal was pinched and rolled over, doesn’t help that the locking area is kinda rusty and weak as well. So might be time for a new tank
I still think something is screwy with the gauge cluster itself. When I try to measure resistance for the sending unit with key on, I get nothing at all. Tore the whole interior apart from the back to the front and couldn’t find one spot where that wire loom was pinched or near corrosion. And I was getting continuous resistance readings from the tank to the dash with key off.
@jrichker I haven’t done the resistor test. Freakin radioshack closed here a few years back and I can’t get into my classroom to snag em because of the covid :poo:. I had to replace my fuel pump so I figured I’d change the 30 yr old sending unit anyway since it was reading empty when I got the car.
There are no motors in these two gauge circuits, only variable resistance gauge senders.
Digikey.com, Newark.com and Mouser ,com have the resistors you need and all of the electronic parts you would ever need.
  • Useful
Reactions: General karthief
Back under the car and dropped the tank. Not seeing any chassis ground screwed into the spare tire well anywhere, is it supposed to be tied into the fuel pump/sending unit harness?
So I pulled the cluster and the sending unit and made a bench top circuit with an extra battery I had. Sending unit works fine, once the signal gets to the cluster is when things get weird. The signal gets screwed up between the gauge and the signal in from the harness. 3 different slosh modules all with the same result at this point. I’m going with its the cluster being bad.
