In the morning or when the car is cold and i floor it, the fuel guage will drop to "E" and stay there for a while, ususally when there is a 1/4 tank or less. Anybody else have this problem??????????
bigcat said:some common suggestions:
use chevron gasoline, or use a techron additive to your tank.
keep your tank full.![]()
Im thinking it has a bad pump/sender, but it also probably electrical, because it only happens when its cold and i run it through the gears, it will read "0" miles to empty, no matter how many gallons are leftbigcat said:yes, techron additive helps. it has been around for a while with corvettes. if it does it often, i would take it in, if it does not do it again, dont worry about it.
gas whih is recomended on the gas cap let me know what happenskillertomato said:I also have come across this issue with my two week old 06 GT. It does seem to happen after sitting for awhile and then being ran "vigorusly". I've been using BPgas whih is recomended on the gas cap
On the third strike shes going in for service.
iskwezm said:In the morning or when the car is cold and i floor it, the fuel guage will drop to "E" and stay there for a while, ususally when there is a 1/4 tank or less. Anybody else have this problem??????????![]()
