I've done the usual checks to see if the gauge or sending unit is the problem:
Grounding wire to chassis doesn't make the gauge go to full
Different sending unit doesn't work either
I've checked voltage at the sending unit wire with power on. I get 5.5 Volts. What should I be getting???
I tested the gauge recently when it was out of the car and it swung to full when i jumpered the right wires on the back, so I'm pretty sure it's not the problem...
FYI - I've got a JME cluster with Autometer Phantom gauges. Everything has worked pretty well for ~8 yrs now, but now have this problem.
Any help would be appreciated!!!
