fuel injection harness
hsean
656
69
69
dearborn,michigan
i have two and i guess there are three different ones i think my harness is from a 92 and i am hoping my harness is from a 93 .what are the differences that i need to be aware of to see if it will match?
The 5.0 Mustang engine mounted fuel injector harness was the same from 87-93.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
I think there was a additional harness that plugged into the "salt and pepper shakers" as a "fix" on one of the years... Im not sure tho.
i can't find where i found that there are three different harnesses the engine harness is from a 93 5.0 that i got from a friend that's going carb.i am not sure if i got the fuel harness as well but hopefully won't be a problem.
HVAC vacuum diagram
Fuse box layout
thanks for the info i will look at the wires to see if they match
What I am thinking of was an extra set of salt and pepper shakers like a extra add on.....I may be wrong.
My current 5.0 has those. It was supposed to be a fix for engine motion causing strain and intermittent connection in the 10 pin connectors. For most owners, it seems that it causes more problems than it fixes.
