fuel injector impedance
forged302
10
Calgary
i have injectors out of a turbo eagle talon i want to put in my 1990 bored 302. i understand stock injectors are high impedance. just curious if you know if these eagle talon injectors are low impedance..... and if they are, its just a matter of hooking up resistors to each bank of injectors right.....??
No info about your car's model year, EFI or carb, no mods listed. Makes it hard to troubleshoot when we don't know what you have.
That's why it is a good idea to use the sig under the user control panel (User CP) option. It allows you to post your car year & mods, which help greatly when troubleshooting things. No, it is not there for us to snoop and see any "Secrets" you have hidden away under the hood. Be a good stangnetter and update you sig for future reference & don't keep us guessing.
What engine changes are you running? The stock 19 Lb injectors are good to 275 HP with some margin for error.
Changing the injectors from anything else other than the stock 19 Lbs will require an aftermaret MAF calibrated to the injectors or a custom burned dyno tune chip to match the injectors.
