Fuel Injector Selection
Rapalyea
17
The car is a Speed Density1988 Mark VII 5.0 HO and I have ordered direct replacement Trickflow heads. Cam, intake and headers remain stock but the car has 2 inch dual exhaust pipes. Trickflow offered two combustion chamber volumes and I chose the smaller one but do not remember the actual cc volume.
My injector choices are 19lb (stock Mark VII), 21lb or 24 lb. I do not plan to go above 5,000-5,500 rpm with this automatic.
Also, there is the issue of old O2 sensors. I plan to keep the original ones unless there is a good reason not to.
Thanks for all the help I have already received. Much appreciated......
It'll be interesting to hear what your recommendations will be. The way I've understood it is the speed density ECM doesn't really respond too well to changing the heads and cam too much. Sounds like it will definitely need a tune afterward? I guess it depends on how far off from stock everything is. But I would venture a guess and say that the 19# injectors will suffice if everything is very close to stock. And your O2 sensors, as long as they are still functioning properly, should be just fine. But like I said, it'll be interesting to hear what someone who is more advanced in the ways of fuel injection will have to say.....
Change it to mass air flow. It isn't really complicated. Then you'll have the ability to tune better. 24lbs wouldn't be a problem with a calibrated MAF.
Don't think the stock speed density system will work well with those mods without a tune. Also you're going to need a fuel pump upgrade if it's stock. I would recommend 24's for the power level you should be at.
Funny thing about Speed Density:) Years ago I put my stock speed density system on top of a 347 stroker and under a Kenne Bell 7psi positive displacement supercharger and it ran like it was factory! Fast factory.... It had a fuel management unit that bumped fuel pressure up by closing the fuel injection return line and 21lb injectors.
This time its just a simple head swap and may increase 50 HP or some such. I am inclined to do 21 lb but my buddy tells me19lb stock would be good enough.
So you're only going to be making 250-275 fwhp? Then 19's will be fine. Most tfs h/c/i need 24's(or even 30's) but they are in the 350+ range. Not sure on the Lincoln system but the fox bodies speed density systems do not like very many cams. Either way make sure you have enough fuel pump.
Fuel injector sizing & injector photos
Revised 26-Dec-2014 to add statement about figures are for flywheel HP and not rear wheel HP
Injector HP ratings: this flywheel HP, not rear wheel HP.
Divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle. These ratings are for naturally aspirated engines at the flywheel.
Example:
19/.5 = 38, 38 x 8 = 304 HP
24/.5 = 48, 48 x 8 = 384 HP
30/.5 = 60, 60 x 8 = 480 HP
36/.5 = 72, 72 x 8 = 576 HP
42/.5 = 84, 84 x 8 = 672 HP
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85.
19/.5 = 38, 38 x 8 = 304 HP x .85 = 258 HP
24/.5 = 48, 48 x 8 = 384 HP x .85 = 326 HP
30/.5 = 60, 60 x 8 = 480 HP x .85 = 408 HP
36/.5 = 72, 72 x 8 = 576 HP x .85 = 490 HP
42/.5 = 84, 84 x 8 = 672 HP x .85 = 571 HP
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
See http://users.erols.com/srweiss/calcpchg.htm to get the calculators used in these examples.
Here's the duty cycle explanation. Duty cycle is how much of the time the intake is open the injectors are turned on. The 85% figure means that for 85% of the time the intake valve is open, the injectors are spraying. The idea is that you want some percentage of the duty cycle left over so that you have some room to grow the process.
If you are at 100% and you need more fuel, all you can do is turn up the fuel pressure. That means the whole fuel curve from idle to WOT is affected. Maybe you are already too rich at idle, and turning up the fuel pressure makes it worse. If you had some injector duty cycle left to play with, a custom tune could use that where it is needed. That would not over richen the whole range from idle to WOT.
If you did turn up the fuel pressure, you might be able to change the injector duty cycle to get the air/fuel mixture ratio you want since the injectors will have extra fuel delivery capability.
With larger than stock injectors or higher that stock fuel pressure, you will need an aftermarket MAF that matches the injector size. The MAF “lies” to the computer to get a fuel delivery schedule that meets the engine’s needs and isn’t too rich or too lean. The best strategy is an aftermarket MAF and a custom tune to insure the best air/fuel ratio over all the RPM range.
Don't forget to increase the fuel pump size when you increase injector size or significantly increase the fuel pressure
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
Reactions: Davedacarpainter
