fuel injectors flow rating in 99 & 01 cobra
These newer style injectors use a different shaped electrical connector. You could use them on your 94 if you wanted to go through replacing all the fuel injector harness connectors with the newer versions.
1994Vib.RedGT said:
it looks like these are the new EV6 type, but in the ford racing catalog it does not state that these cannot be used in certain years, so is it a certainty that they will not work???:shrug: :shrug:
They'll work but you will need to either put new connectors on your harness or buy adapters. The adapters are pricey, so unless you are getting the injectors for next to nothing, not worth it.
Ken
