Fuel injectors how to test
  • Thread starter Thread starter stevesLX
  • Start date Start date Mar 24, 2007
First Prev 2 of 2
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 26, 2007
#21
  • Mar 26, 2007
  • #21
If you want to find if the injector leaks, take the injector completely off the car. Then use
the compressed air and soapy water to find if it leaks with no electrical signal applied
to it. A leaking injector will make bubbles when compressed air is applied. No bubbles
and the injector does not leak.
Remember that this does not test the spray pattern, it merely spots injectors that pass air
with no electrical signal to tell them to open.
stevesLX
373
cincinnati
Mar 26, 2007
#22
  • Mar 26, 2007
  • #22
I have my compressor at 100psi and I am going to use a blow gun with a tube on the end of it. I just want to make sure that its not going to be to much air pressure.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 26, 2007
#23
  • Mar 26, 2007
  • #23
Use a regulator and dial the pressure to 40-45 PSI. That will mimic the pressure of the fuel system.
HISSIN50
34
129
Mar 26, 2007
#24
  • Mar 26, 2007
  • #24
As JR said, you're not runnin soapy water through the injector, and the soap that touches the outside isnt going to hurt anything. I'd personally keep 100 PSI compressed air (on the outside or through the body) away from my injectors though.
stevesLX
373
cincinnati
Mar 27, 2007
#25
  • Mar 27, 2007
  • #25
Well I tested all the injectors last night with the air and soapy water and they are all good none are leaking. So whats next. Also what is a shrader valve? And just to let you know I have been up in the engine compartment when the car has been shut off or stalls out and the fuel pressure guage drops to 0 within a 1 1/2 seconds.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 27, 2007
#26
  • Mar 27, 2007
  • #26
The schrader vavle is located in the fuel injection pressure feed line just behind the alternator.
It is for the fuel pressure test gauge. If you have an under hood or passenger comparment
gauge, it may have been removed to provide a pressure source for the gauge.
fuel pump pressure test
Disconnect the larger of the two fuel lines up by the Schrader valve. It is the return line and
does not have the Schrader valve on it. Find a piece of rubber fuel hose and clamp it on
the return line coming from the regulator. Stick a bolt in the other end of the hose and
make sure that all your connections are tight and leak proof as possible. When this
powers up, you don't want fuel squirting everywhere. Hook up the fuel pressure test gauge.
Turn the ignition switch on and watch for leaks. You may want to use a helper inside the
car to cut the switch off quickly if you have a leak. To trick the fuel pump into running, find the ECC
test connector and jump the connector in the Upper RH corner to ground.
Caution!!! You have blocked the return line for the fuel pump! Pressure will
rise very quickly past safe levels with a good pump
If the pressure goes up
past 55 PSI, the pump is good and the fuel pressure regulator is bad. If the fuel pressure does
not hit 55PSI or more in a few seconds, the pump is bad or you have electrical problems.
If the pressure drops more than 15 PSI within 60 seonds, the check valve in the pump is bad.
If the pressure holds and does not drop off, then the fuel pressure regulator is suspect to
be the cause of your pressure drop off.
stevesLX
373
cincinnati
Mar 27, 2007
#27
  • Mar 27, 2007
  • #27
O.K. I dont have a shrader valve. I have a autoguage fuel pressure guage that is inline right there where that once was. So can I just use that as my guage. And do I just turn the key forward or do I have to start the car?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 27, 2007
#28
  • Mar 27, 2007
  • #28
Beware of sparks and potential fire hazard!
Jumper the fuel pressure test point to test ground or chassis ground. Either one will do.
Turn the key to the Run postion. Do not try to start the car. Have your helper stand by to turn off the ignition switch.
stevesLX
373
cincinnati
Mar 28, 2007
#29
  • Mar 28, 2007
  • #29
O.K. I must be doing something wrong here. I disconnected my return line way down in the engine compartment. I have a spot where there's a quick disconnect just as the fuel lines bend over and go straight down towards the ground back behind the altenator. I put a hose on the one that goes back up to the regulator and stuck a bolt in the one end of it and the other end that was disconnected from it that goes back to the fuel pump is sitting wide open. When I turn the key forward nothing happens my guage that I have in line doesn't move. It stays on 0.
ronburgundy
179
BC coast
Mar 28, 2007
#30
  • Mar 28, 2007
  • #30
sounds like a faulty pressure reg. if your squirters aren't leaking.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 28, 2007
#31
  • Mar 28, 2007
  • #31
Is the fuel pump running?
stevesLX
373
cincinnati
Mar 28, 2007
#32
  • Mar 28, 2007
  • #32
When you turn the key forwaqrd you can hear the fuel pump kick on
stevesLX
373
cincinnati
Mar 28, 2007
#33
  • Mar 28, 2007
  • #33
O.K. I got it to work now the first time the key was turned forward my fuel pressure guage only shot up to 40. And it stayed there forever. So I turned it on again and it went from 40 to like 70 I releived all the pressure and turned it on again and it shot up to 52 or 53 and pretty much stayed therte. I releived the pressure again and did it one more time and once again it shot up to 52 or 53. So a few psi off 55 what do you think. Pressure regulator or fuel pump. I know I hooked everything back up and started the car and it did its normal thing loped for a minute and then stalled out the pressure dropped straight to zero in about 1 second. Thats what it always does. The line never holds pressure longer than a second after you turn the motor off. I am guessing now because like I said the first time it only shot up to 40 but each time after releiving all the pressure it went to 53.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 29, 2007
#34
  • Mar 29, 2007
  • #34
If the pressure holds steady for 60 seconds after you turn the pump off, the pump is OK and the fuel pressure regulator is suspect.
First Prev 2 of 2
  • dan50
  • Jul 18, 2026
dan50
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
A
Resolved Fuel pressure high at 52 new FPR same thing
  • afjLX
  • Dec 28, 2024
  • 3 4 5
5K
Fox 5.0 Mustang Tech Jan 11, 2025
AeroCoupe
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
