Fuel injectors that dont exist
  • Thread starter Thread starter COMPSYSTEMS
  • Start date Start date Jan 16, 2011
C
COMPSYSTEMS
  • Jan 16, 2011
Hello,
Im trying to find out what PPH my fuel injectors are. I am doing a Carb to EFI swap and got everything at the junk yard from an 88 5.0
The injectors are PN 01D062B
Iv already used the search and Google and found nothing, These dont exist anywhere!
They look similar to stock 88 mustang 5.0 injectors
I tried setting my tune at 19lb but it wont start just pops out the exhaust like a bad fuel\air mix.
Already tested and injectors all fire correctly. I am sure its a tune issue.
Anyone know what the fuel flow rating is for so I can at least tune it?
Why does this part number not show anywhere?
HISSIN50
34
129
Jan 16, 2011
  • Jan 16, 2011
what color are they?
giddyup306
3,041
Jan 16, 2011
  • Jan 16, 2011
This right here makes me think it's a valve or ignition timing issue.
The stock HO injectors are #19's (yellow). I also think that some 302s had 16# (grey) injectors.
J
Justang87
Rockford IL
Jan 16, 2011
  • Jan 16, 2011
one other thing to check is if you just swapped the intake to do the injection swap is a vacum leak. i replaced cam in mine and it would not start after installing and sounds similar to your start up problem. when i bolted the intake down the gaskets settled and exposed the tops of the port holes in the intatake gasket, could not see it by eye, but backfired once while i was watching it and saw the flame between the intake and head.
C
COMPSYSTEMS
  • Jan 17, 2011
injectors have a blueish geen ring on them.
From what I know thats a Bosch ID ring for 24lbs
But these injectors look like maybe accel or delphi as well, Do they follow the same color code?
I dont think its an intake leak but i guess its possible, no coolant leaks at the gasket makes me think its sealed ok.
Valves were good before intake swap
Ignition timing has been verified at 12Degrees while cranking.
The big question is...who makes these injectors? I would like specifics to flow rate @ PSI and open\close response time.
Thanks for the replys
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 17, 2011
  • Jan 17, 2011
The intake gasket can easily slide out of place when the lower intake is put in place. A low vacuum reading is the tip off - less that 12 in. of vacuum at idle , no idle is possible.
My favorite trick that saves time and effort is the stay in place gasket. Be sure that you scrape (don't use a wire brush) all the old gasket material off, then clean all the surfaces with acetone or MEK.
When the surfaces are clean, use weather strip adhesive on the head to manifold surface. Also use the weather strip adhesive on the side of the gasket that mates to the head. When you are done, the head surface and the gasket surface that mate together will have weather strip adhesive on them. Follow the instructions on the tube or can and when it gets tacky, press the gasket down on the head.
Clean the area where the rubber rails mount to the block in front and in the rear with more acetone or MEK and do the same trick with the weather strip adhesive that you did to the heads.
Coat the rubber seals and the gasket area around the water passages with lots of Blue Silicone gasket sealer and put it together. TADA! no leaks, and no gaskets that shifted out of place.
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Fuel Spits sputter pops and bangs under load. Help wanted
  • sickntired
  • Mar 23, 2024
4K
Fox 5.0 Mustang Tech Apr 1, 2024
sickntired
Fuel fuel pump relay?
  • maxine-70
  • Nov 30, 2023
2K
Fox 5.0 Mustang Tech Dec 4, 2023
Shawneebear93
