Fuel injectors
Will all fuel injectors made for Fords work on the 4.6 2v? Such as can i take the stock 24# injectors from a 05+ 4.6 3v and put them in my 00 GT? Or the ones made for the 5.0? Etc... (I realize i would need to retune in the SCT, but thats not my question. I am referring to them actually fitting into the fuel rail, heads, and wiring)
Thanks,
Alex
Have you added a power adder that would require larger injectors?
If not larger injectors will do nothing for you.
I am sure they will fit but I think the connector is different
I know I haven't answered your question but I don't know the answer to that one.
Dwayne
To answer your question yes the 05 mustang is an 11-18 ohm injector the same as the 00 model. As long as the connectors are the same they would work but, as stated in the 2 previous post unless you are adding some kind of power adder like a SC it would be a big waste of time and money.
