Fuel issue 2000 v6
Nijiel777
Oregon
Hello,
Trying to get my stang to start after sitting for a bit. Did a basic tune up. Car cranks but does not start. I tested the wiring harness to the fuel pump and two pins show no voltage. Is this normal? If so, good chance the fuel pump needs to be replaced?
Thank You
Hello,
Thank You
If the fuel pump harness is getting power the relay must be operating correctly, right?
It's unclear to me EXACTLY what connection and which pins you are testing.
The initial GOLD standard test for the fuel pump is to test for initial key on power at the trunk mounted IFS switch. Use a test light that will "load" the circuit. It may be necessary to cycle the key on/pause/off while watching the test light. What to do next depends upon the results of this GOLD test.
Here is some more information that if followed should help.
1996+ Crank with no start check list
