The vehicle is a 1996 mustang GT and i'm looking for the flexible/ rubber fuel line that goes from the hard line near the fire wall to the fuel rail. Does any one know where i might be able to buy a replacement? Thanks in advance
I am sure you could always get the appropriate adapters from summit and make your own out of -6 line.. But if Randy has any advice, it might be cheaper..
ok lets say that for this fuel line problem that i have done the conversion on the fuel rail for the braided line,ok. Now where do i find the connector for the hard line that near the fire wall?
Sorry SILVER but lethalperformance DOES'NT have it. They said nope . Maybe if you would know the part number from them or either summit? Darn such a small piece and know body knows about it.
Apparently not, I know lethal carries all that **** for the returnless systems.. I guess you guys have a different connector??
You might have to run an aftermarket line from your tank output to your fuel rail. then you should be able to use this connector to adapt to the fuel rail-
the part number is to the piece that goes onto the fuel rail. i need the part that goes to the other end which is the one on the hard line. i looks just like the same one thats used when you change your fuel filter, with the white clip that pulls out.
