Fuel mixing with oil and plugs soaked with fuel....causing the car not to start,help!
StreetDreamsGT
449
New Jersey
Hey guys, I have a low milage 302 block from an explorer, just about everything on it is brand new,....check sig for details.....originally the car seemed to be running rich so I put my stock injectors back and my stock mass air meter, the car ran fine then. I put the front of the car up on ramps cuz I had to do some work under it. One day I went out to start it and it wouldn't start up, I checked the oil and fuel had mixed with it, I pulled a couple of plugs and they were soaked with fuel, I went out n got new plugs and put em in, car still wouldn't start. I checked the afpr and there's no fuel comming from the vaccuum connection, the only thing I can think of at this point is the injectors, but shouldn't it have started after putting the new plugs in?
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 06-May-2007 to update PIP sensor information
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
J.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
F.) Engine seems to load up on fuel and may have black smoke at the tailpipe. Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running. If fuel is coming out the vacuum port, the regulator has failed. Check the regulator vacuum line for fuel too. Disconnect it from the engine and blow air though it. If you find gas, the regulator has failed.
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. It is cheap if you have the stuff lying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage. It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: this is only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Yes, you may be running very rich. Too rich, and you'll probably never burn all the fuel, so it'll end up washing the cylinder walls, and mixing with the oil. What do you have your fuel pressure set to currently? It should be ~39lbs with the vacuum line disconnected.
dude i had the same exact problem about 6 months ago after a rebuild...
After alot of searching and looking for the problem i realized that the fuel pressure regulator(stock at the time) was stuck and the thing inside was ripped(i cant think of what that part is called right now)
So i bought an adjustable one and put that on, adjusted the pressure and it was fine.:nice:
It was crazy though, the oil was thin as water with the gas in it
I have custom braided fuel lines running to the rails, so there's no way for me to check, but when I got my aftermarket fpr I just tossed it on without messing with the settings. The only thing is, I've had it up and running before with the regulator like that, why could it be it's acting up now? Does it have anything to do with me having it up on ramps in the front and not on ramps in the back?
Ok so I went through everything for the fuel system yesterday n it turns out the fuel system is fine, although i'd checked all the wiring for the ignition system, and all the appropriate power wires were getting power, I pulled a plug n placed it near the block n noticed it wasn't getting any spark, the coil, plugs, plug wires, and cap and rotor are all new, i'm guessing it's probably the distributor module, how can I test it to be sure?
Go back to the checklist - make sure you have a PIP signal. No PIP signal, no spark or injector pulse. See paragraphs 1 D and 5 A.
The TFI module can be checked at most auto parts stores for free.
Well instead of doing that I tossed in another distributor and it still wouldn't start.
I tried doing this test,
Connect a 12 volt test light from the negative coil terminal to the negative battery terminal and crank the engine. The test light should flicker as the engine cranks. The flickering test light indicates that the TFI module is probably operating correctly and collapsing the primary winding in the coil during engine crank. If the test light does not flicker, check the coil as specified below, and if the coil is OK, replace the TFI module.
And it didn't flicker with either distributor, however when I checked the resistance across my coil it would first be around .3 or something then hit one and stay there, the coil is brand new so I wouldn't expect that to be bad, same thing for the plugs, wires, cap and rotor, and now I tossed in the other distributor.....I know the injectors are firing because I can smell the gas fumes and there aren't any leaks anywhere, and the plugs still end up with fuel on them.
If fuel has mixed into the oil change the oil and filter and remove all plugs and clean them off again with some brake clean or one of those spark plug cleaners ( small sandblaster type)
I have had a few cars that had so much fuel in the oil that even with new plugs the fuel vapors from the oil caused it to be too rich to run. This happens quite a bit, we see lots of even brand new cars flooded so bad we have to do this.
If this dont work then check the fuel presure.
Ok, so it occured to me that i'm a moron and when I installed the other distributor I forgot to put the engine at top dead center......did that n she fired right up. As far as the fuel in the oil I'm guessing it's because of the injectors.
you could pull the rails out of the manifold with the injectors still clipped in and run the fuel pump (jumper it to power) while watching the injectors to see if they leak. you should put a T fitting in your fuel line somwhere so you can check your fuel pressure and adjust it where it needs to be.
If you can get the engine to run, here's the test...
Fuel pressure OK, the injectors are not firing, OR one or more injectors stuck
open
Do a cylinder balance test: Warm the car's engine up to normal operating
temperature. With the Engine Off, Key OFF, use a jumper wire or paper clip to
put the computer into test mode. Start the engine and let it go through the
normal diagnostic tests, then quickly press the throttle to the floor. The
engine RPM should exceed 2500 RPM's for a brief second. The engine will shut
off power to each injector, one at a time. When it has sequenced through all
8 injectors, it will flash 99 or the number of the failing cylinder such as 22 for
cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause
the test to re-run with smaller qualifying figures. Do it a third time, and if the
same cylinder shows up, the cylinder is weak and isn’t putting out power like
it should. See the Chilton’s Shop manual for the complete test procedure
The red wire on each injector is powered up whenever the ignition switch is
in the Run position. The computer provides a ground to complete the circuit
and fire the injector. The injector must have a ground to squirt fuel on
command. A short to ground in the injector return wiring can cause one or
more injectors to be continually open or triggered
A.) A Noid light available from Autozone, is one way to test
the injector wiring. If the light stays on constantly, either the wiring has a
short to ground or the computer has failed
fires, it makes bubbles An injector stuck open will release a continual stream
of bubbles. Cheap if you have the stuff laying around, and works good too.
The same trick works great to find leaking injectors too.​
The wiring for the injectors may have some bare spots in it causing the
injector to computer control wire to ground out. This would cause the
injector to remain on anytime the key was in the Run position. Remove the
injector wiring connectors from the injector. Note that each injector has one
red wire for power and a non red wire (wire some color other than red) for
computer controlled ground. With the key off, disconnect the computer
connector from the computer. Use an Ohmmeter between the non red wire
and ground. You should see more than 100000 (100K) ohms resistance.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host) for help wiring http://www.veryuseful.com/mustang/tech/engine/
Using the above diagram, check the resistance between the injector and the
computer. Clean and check the 10 pin connectors since they are a potential
trouble source. Any resistance greater than 1 ohm between the injector to
computer wire and the matching pin on the computer connector is a problem.
See http://fordfuelinjection.com/?p=6 for more help
Here's the link to dump the computer codes with only a jumper wire or paper
clip and the check engine light, or test light or voltmeter. You’ll need it to do
the cylinder balance test
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
