fuel options for forced induction
stanggt00
371
baltimore md
hey guys can anyone give me stats on fuel options for a boosted gt
i want to keep the car returnless but i also want to make about 600whp
i just picked up a 03 cobra fuel tank and dual stock pumps for 600 off ebay
what is the max i can get out of this before i need a boost a pump or ford gt pumps
atm the car has the svt focus pump on it not sure what the max is on that...
whats the max hp with :
stock gt tank and svt focus pump
03-04 cobra tank w/ stock dual pumps
03-04 cobra tank w/stock pumps and boost a pump
thxs for any help
also if i want to upgrade the fuel line from the tank to the motor what size should i be looking at ie. -4,-6,-8,ect
need help mmr900 and t45 tranny connction.
ok guys i got the mmr900 motor in the car guy that dropped the motor in for me after i put the motor together said he can't get the clutch to engage ......
i dropped the car off to aacom transmission shop
they are telling me the same thing that after removing the tranny and hooking it back up that the clutch is not engaging some thing is being pinched the fork on the tranny is not moving its very tigth.........
the orginal motor had alum 6-bolt flywheel and cenfg. clutch
if i am correct the t-45 uses a 10.5 flywheel and clutch.. rigth
my car is a 2000 gt
the mmr900 motor has 8-bolts so i got a stock flywheel and was going to use the same clutch
i still dont understand why they are having such a hard time with this
Focus pump is around 400-450rwhp.
Cobra tank+pumps is 500ish i believe. not sure about boost a pump numbers.
you could also buy another Focus pump and run dual Focus pumps with the Cobra tank, or buy dual GT pumps.
dont mess with the focus pumps. run twin GT supercar pumps. they are cheaper and better.
i'm running twin GT pumps, PPRV delete, 40 amp BAP, stage 1 driver module, wiring upgrade,CPR rails and 60# injectors. i'm seeing mid 80% DC with my setup
ok -8an line from the tank to the rails got it. thxs
ok sounds like i should be good on fuel up to about 500-550 rwhp just with the cobra fuel tank,stock pumps and bap
i will check with the transmission shop on the pilot bearing ......
also once i can get this tranny thing fixed i will then drop the car off to jpc performance to have the cams degreed and the car tuned
i will have :
mph blower cams
patriot stg2 heads
mmr900 shortblock
sq-trim vortech 3.60 pulley
stock fuel tank with svt focus pump
------------(dyno numbers will be posted)---------
same as above
with cobra fuel tanks
sq-trim vortech 3.12 pulley
custom fmic
----------(dyno numbers will be posted)-------------
the goal is 500 horses to the ground..
i will have :
mph blower cams
patriot stg2 heads
mmr900 shortblock
same as above
custom fmic
Heck man you got the motor, throw a 2.90 or 2.75 on that SOB!
