I have a question regarding my mods and what you all think I should be running for fuel pressure and timing.
Here are the mods.
Engine Modifications:
1986 Ford Mustang GT
-Ford E7 Cylinder Heads, Ported and polished with a 5 angle valve job, and Performance Vassco Dual Springs, Moley Keepers and Retainers
-Ported Lower Intake Manifold off of a 1986 Mustang 5.0
-Upper Intake off of a 1993 Ford Mustang 5.0
-Mass Air Conversion
-1/5/8 Jet-Hot Coated Pacesetter Headers
-Kirban Adjustable Fuel Pressure Regulator
-Pacesetter Off Road H-Pipe
-Flowmaster 3 Chamber Exhaust
-65mm Ford Racing Performance Throttle Body and EGR Spacer
-3.55 Rear End Gears
-19 Pound Fuel Injectors
-Ford Motorport 9mm Spark Plug Wires
-MSD Blaster Coil
-Modine 3 Row Radiator
-180 Degree Thermostat
-Pro 5.0 Power Tower Shifter
-140 Amp Powermaster Alternator
-K&N Conical Air Filter
-ARP Head Bolt
I want to know what I should set the fuel pressure at. I know it says to undo the vacuum and then set it and replace the vacuum line. I do not have the sheet on me that tells the specifics, so what do you all run? Second. What should I run for timing? I use 93 octane right now. At what time should one go from 90 to 93 octane as far as timing goes? I have experienced pinging at about 14 degrees, so I think I have it at about 10 right now. I just want to see what you all run if you have a combo comparable to mine. I get 14 mpg in the city and 20 on the highway. This seems low to me. Would 3.55 gears cause my mileage to drop this much? Thanks!
Here are the mods.
-MSD Blaster Coil
-ARP Head Bolt
