fuel pressure gauge inside the car?
you need a pressure guage islolator. It's just a barrel looking thing you connect the pressure hose to and it comes with a line to run inside the cabin that is filled with fluid to run to your gauge, so if you have a leak in the interior it only leaks maybe 1/4 ounce of fluid.
I'm assuming you wanted to run a mechanical guage right? lol
it not really to keep leaking to a minimum, it's more for safety reasons. it's not safe to run gasoline into the cabin of your car, so you run the isolator from a braided hose coming from the shrader valve, to the back of the gauge. the isolator and hose coming off the isolator to the gauge is filled with coolant rather than gasoline. it's also recommended that you mount the isolator level with the gauge because the weight of the fluid can make the gauge off by a bit.
i have the whole mechanical setup sitting in my room. you can go that route, or for about the same price and less hassle, you can run an electrical gauge. here's the isolator you need for a mechanical gauge:
you'll also need another braided hose to go from the shrader valve to the isolator and then any mechanical gauge you want. the isolator is about $100 and is made my autometer. you can get it anywhere, ebay, summit, jeggs, etc. and a mechanical gauge is around $55 depending on which one you get. an electrical gauge is about $160 - $200, again depending.
i haven't decided yet, it's been sitting in my room for about 7 months, never been used. i have a gauge mounted under my hood right now. and yeah, with the electrical gauge, it's all wires, the isolator's not needed.
yeah it's accurate. what do you mean samick? oh and yeah its the same for oil pressure gauges. i have an electrical oil pressure gauge in my car right now. the gauge comes with an electrical switch (or sending unit) that you mount in the same place as your original pressure switch. then just a single wire from that to the back of the gauge. the only other wires are a ground wire and a power wire, then 2 wires for the backlight. both gauges are easy to install.
I'm with cenok on the 'type' of gauge to use on a street car.
As for as I'm concerned (yes, it's personal preference), electric is the way to go. I don't like the idea of having a cumbistable liquid pass through my firewall into the personell cabin. I'm also not a huge fan of having an isolator and/or tubing that is filled with gas, floating around my engine bay if it's anything less than totally secured.
I use the Kenne Bell fuel pressure gauge (electric). It's white faced and analog. It's also a good match for my stock 86 gauge cluster when it's dark out and the amber background lights are on.
As far as accuracy... I can't imagine being more accurate than a direct reading, mechanical gauge but I gotta tell ya that my electric kit is close enough that you'd not be able to tell the difference with your eye across side by side analog setups. I at least, was not able to read a differentail between an under hood gauge (temp installed on the fuel rail) and my in-car gauge. The mechanical gauge did react faster though that might just be the result of the how the sweeping motion was built into the electronic gauge.
