fuel pressure gauge
  • Thread starter Thread starter DURRETT
  • Start date Start date Aug 9, 2007
D
DURRETT
18
  • Aug 9, 2007
I bought a fuel pressure gauge that installs where the shrader valve is on my fuel rail if i unscrew the valve what will happen need help with install
fastford91
254
Niagara ,Ontario, Canada
Aug 9, 2007
  • Aug 9, 2007
nothing will happen ...... well maybe a little gas will spill out but thats about it! make sure the engine is not hot when you do this! or you risk a fire! it's an easy install just undo it put new teflon tape around the threaded part and put new one on!!! turn on ignition dont start it ! look for leaks! if none are found your good to go! simple!
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Aug 9, 2007
  • Aug 9, 2007
most little gauges have a 1/4 NPT thread on them and the valve on the rail is 1/8NPT you need an adapter if you didnt get one, my little gauge is a pro products and they also carry the adapter.
D
DURRETT
18
  • Aug 9, 2007
cool thanks for the help
G
getusummm
156
  • Aug 10, 2007
Actually the valve that screws into the rail is 1/16npt. The fuel guage adapter can be either 1/8npt or 1/4npt depending on brand.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Aug 11, 2007
  • Aug 11, 2007
yeah your right, i forgot about 1/16th pipe
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Aug 11, 2007
  • Aug 11, 2007
Just let the car sit overnight and then do it first thing the next day. That way the pressure has a chance to bleed down and the engine is cool.
DOn't use teflon tape to seat the threads. Use that thread paste and allow it to set up before pressurizing.
gas eats teflon, so i used it once anda bit of teflon floated up into my FP gauge and blocked the port and gave false readings. I only by chance discovered it when i looked inside and barely got the peice out. I got very lucky it didn't go into my injectors
cenok is family
1,409
69
79
Norman, Ok
Aug 11, 2007
  • Aug 11, 2007
hmmm...i should probably get the teflon tape off of my gauge then.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Aug 11, 2007
  • Aug 11, 2007
If you just tefloned the threads and nothing protruded into the fuel, you should be fine really. I was just a sloppy jalopy when i did mine
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
Aug 11, 2007
#10
  • Aug 11, 2007
  • #10
You should also be able to take a rag and pen cap and bleed the fuel out of the rail so it's not under pressure when you try to install the gauge. It'll re-pressurize next time you turn the car to crank.
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
C
Looking for electrical schematic 1986 GT
  • CMT3
  • Sep 21, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 23, 2026
AeroCoupe
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
