Resolved Fuel pressure high at 52 new FPR same thing
  • Thread starter Thread starter afjLX
  • Start date Start date Dec 28, 2024
  • 3
  • 4
  • 5
First Prev 3 of 5 Next Last
A
afjLX
83
20
18
DFW,TX
Jan 2, 2025
#41
  • Jan 2, 2025
  • #41
Noobz347 said:
Unfortunately, no.
In my theory, your engine combo and injectors are not using enough fuel for your return line to accommodate a 255L pump. HP, LP, doesn't matter.
Your solution of a 190L I think is a good one. You need to reduce the volume you're sending to the rails because you're bypassing [too much] fuel at the regulator.
What's your engine combo? NM - I see it: Trickflow and E-303.
That's my theory and I'm sticking to it. A smaller pump should fix this.
I think so. I will go with a 190 and report back. Damnit, have to drop the darn tank again. I’m a tank dropping expert now. Sheesh.
Admin Dude
Jan 4, 1985
43,353
21,555
234
Box behind Walmart
Jan 2, 2025
#42
  • Jan 2, 2025
  • #42
For reference, In my combo:
347
heads
cam
KB blower that pulls between 6 and 8 HP at idle.
42s
Be advised: There are low pressure and high pressure 190L pumps as well.
I generally recommend the high pressure no matter what. I don't know if it's still true or not but the low pressure Walbro 190L LP pumps would "pop-off" internally at around 60 psi. So, no boosted apps with FMUs. The HP pressure versions have a much higher internal pop-off (90 to 100 psi IIRC).
A
afjLX
83
20
18
DFW,TX
Jan 2, 2025
#43
  • Jan 2, 2025
  • #43
347
heads
cam
KN blower that pulls between 6 and 8 HP at idle.
I was gonna order the gss242 from summit and reuse the filter sock off the 255 unit. Is the gss242 the right pump?
Reactions: Noobz347
Admin Dude
Jan 4, 1985
43,353
21,555
234
Box behind Walmart
Jan 2, 2025
#44
  • Jan 2, 2025
  • #44
Specifications:
  • Fuel: Gas
  • Horsepower: 300-400
  • Flow Rate: 190 lph
  • Flow @ 40 psi: 50 gph
  • Fuel Pressure: 50 psi
  • Maximum Working Pressure: 137
That's the one.
Admin Dude
Jan 4, 1985
43,353
21,555
234
Box behind Walmart
Jan 2, 2025
#45
  • Jan 2, 2025
  • #45
I dug this up for you to checkout when you have the inclination.
It explains what I talked about above with graphs and tables and things...
Note the [Download] Button in the upper right. It's an old magazine article:
Fuel Flow Forensics
Jun 1, 2017
fuel flow forensic
  • Noobz347
  • bap boost-a-pump fuel flow fuel flow forensics fuel pump
  • Mustang Reference Material
A
afjLX
83
20
18
DFW,TX
Jan 2, 2025
#46
  • Jan 2, 2025
  • #46
Fuel Flow Forensics
Jun 1, 2017
fuel flow forensic
  • Noobz347
Thanks!! I’ll check it out!
For some reason summit only lists a gss242BX for the pump only??it Looks like the right one?? I couldn’t find just a gss242 listed.
Admin Dude
Jan 4, 1985
43,353
21,555
234
Box behind Walmart
Jan 2, 2025
#47
  • Jan 2, 2025
  • #47
It should drop right into the hanger you have for the 255. They should be physically similar.
AeroCoupe
6,135
4,220
183
Claremore, OK
Jan 2, 2025
#48
  • Jan 2, 2025
  • #48
I have run a 255 lph high pressure pump for over 15 years in my Coupe with three different motors and had zero issues getting the pressure down to 39 psi. At idle the fuel consumption difference on a stock 302 versus one with all kinds of bolt-ons and with both of them being NA is going to be minimal. Larger displacement or boosted applications will use a little more. Where things differ is when the foot hits the gas pedal.
Not being able to adjust the pressure up or down is like the return line has an orifice in it upstream of the pressure regulator so it basically negates the regulator. Is there an obstruction in the fuel rails? I just cannot see this being a fuel line size issue as thousands of these cars run 255 lph pumps with no issues.
Reactions: nickyb, nicholase and General karthief
A
afjLX
83
20
18
DFW,TX
Jan 2, 2025
#49
  • Jan 2, 2025
  • #49
No orifice or restrictors or check valves, etc. anywhere. Did fuel line size change at all throughout the years? This car was an 87 4cyl before a 5.0 swap. Could the fuel lines be smaller on an older mustangs or 4cyl?
AeroCoupe
6,135
4,220
183
Claremore, OK
Jan 2, 2025
#50
  • Jan 2, 2025
  • #50
Okay, that is something we need to know. When I swapped my car I installed V8 lines due to the 4 banger lines running on the driver side and the V8 lines running on the passenger side. Line size between the V8 cars and the 4 cylinders are the same which are 5/16" feed and 1/4" return. My guess is whoever did the conversion swapped to the V8 lines on your car?
Fuel Thread '4 Cylinder Fuel Lines'
Oct 31, 2017
How do the 4 cylinder fuel lines run underneath the car? I am speaking specifically about fuel injected cars. The pump is still in-tank I am assuming. What about filter location? I am sure some of you have ripped into a 4 cylinder to install a 5.0. I am just curious. Here’s why; If the lines meet the engine at the rear wouldn’t that match up better with roller cam 351 fuel rails? Let me know. Just a thought.
  • nelzfoxes
  • Forum: Fox 5.0 Mustang Tech
A
afjLX
83
20
18
DFW,TX
Jan 2, 2025
#51
  • Jan 2, 2025
  • #51
Oct 31, 2017
  • nelzfoxes
Lines run down the psssenger side so they appear correct. One question though, how are the stock lines routed? Do they make a 90 at the back near front of the rear wheel towards the center of the car then outback to the fuel filter? It looks like a stock setup but you never know.
AeroCoupe
6,135
4,220
183
Claremore, OK
Jan 2, 2025
#52
  • Jan 2, 2025
  • #52
They run down the passenger side and about midway down they move to the drive shaft tunnel and run along it until it gets to the rear axle area. From there they run along the sheet metal to directly over the rear end and then it switches to rubber lines from there over to the tank and the filter.
A
afjLX
83
20
18
DFW,TX
Jan 2, 2025
#53
  • Jan 2, 2025
  • #53
I verified the routing using LMRs diagram, they appear to be correct v8 lines.
Reactions: AeroCoupe
AeroCoupe
6,135
4,220
183
Claremore, OK
Jan 2, 2025
#54
  • Jan 2, 2025
  • #54
You proved the regulator will regulate in Post #26 and that there is a restriction somewhere past the steel line that connects to the fuel rail.
The two plastic lines that go from the hard lines just in front of the passenger wheel then over to the two hard lines that connect to the fuel rails have a hard foam / rubber protective covering around them from the factory. Does your car still have them? If so are you sure the return line under it is not kinked?
A
afjLX
83
20
18
DFW,TX
Jan 2, 2025
#55
  • Jan 2, 2025
  • #55
I pulled the rubber off both. The supply line had a slight kink. Return line was ok. Fixed the kink and then eventually tested with return line dumping into a bucket.
A
afjLX
83
20
18
DFW,TX
Jan 2, 2025
#56
  • Jan 2, 2025
  • #56
Update:
Well, installed the walbro 190 and cranked it up. Fuel presssure was at 30psi and I was able to adjust it to 40 without vacuum. So it does appear the 255 was overloading my return line. Maybe I got a really well built 255 that was pushing 99% efficiency and flowing every bit of its rated flow?
The Walbro 190 is on and I can now adjust fuel pressure. Thanks to everyone for their help!!
Reactions: Noobz347
Admin Dude
Jan 4, 1985
43,353
21,555
234
Box behind Walmart
Jan 2, 2025
#57
  • Jan 2, 2025
  • #57
afjLX said:
Update:
It not actually the first time I've seen this happen but it's been rare.
The trouble is that if the return side is just [barely] able to handle the volume then the pressure rise accumulates fast (hydromechanics are a beeoch).
The good news is that you're not burning much fuel at idle.
it takes a little bit to get one's head wrapped around the difference between pressure and volume in a closed hydraulic system. I could probably take your return system, put it on my car, and it would be just fine.
Reactions: afjLX
gkomo
now i can hopefully expect to receive the shaft
Aug 2, 2024
2,268
1,495
133
San Diego, CA
Jan 2, 2025
#58
  • Jan 2, 2025
  • #58
Kinda scares me to install my 255lph Walbro pump on my stock (for now) car.
nickyb
I gotta say i never painted my nuts, Never Ever
3,014
1,650
163
nevada
Jan 2, 2025
#59
  • Jan 2, 2025
  • #59
Don't be. I've run mine for ten plus years ,no problem with pressure,stock regulator.
Reactions: gkomo and AeroCoupe
AeroCoupe
6,135
4,220
183
Claremore, OK
Jan 2, 2025
#60
  • Jan 2, 2025
  • #60
All I have to say is glad you got it figured out and this is the first time I have ever seen or heard of this but I have never thought to research a 255 being too large based on my experience and other cars I have been around with them. Kinda crazy how you can run an intank 255 plus an inline 255 and not over pressure the stock lines with a supercharger or turbo car at idle. IDK but still really glad you got yours figured out.
Reactions: afjLX
  • 3
  • 4
  • 5
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
Zero fuel pressure @ Shrader, but over 100 PSI at filter
  • Stang337
  • Jul 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 10, 2025
JD1964
  • dan50
  • Jul 18, 2026
dan50
