I need some assistance guys. Just bought a one owner 91 LX that has been sitting in the garage for about 3 years. It would turn over but would not start. It was running when it was parked. The car was in good condition overall so I bought it anyway. I started working on it today and I cant get any fuel pressure. I dropped tank and cleaned it out. Installed new fuel pump, fuel filter and fuel pump relay. Checked the fuel switch in the trunk also but I still have no pressure at the fuel rail. I also checked voltage at the pump and its good. Any other ideas??
(Update) Problem solved. First, thanks for the suggestions guys. Second, it would help if I looked at the right print for my year model.
I started over and had 12 V on the pink wire but relay would never click on. Checked voltage at the PCM relay and had 12V on the yellow but the relay would never engage. The problem ended up tracing back to the ignition switch. Replaced ignition switch. I also decided after the fact to replace the PCM relay also. It worked but it looked rough so I replaced it while I was thinking about it. Even though it had been sitting a few years it fired right up. Now its time for a tune up(wires, plugs, etc). Thanks again for the suggestions .
