fuel pressure question (or problem)
  • Thread starter Thread starter jhonda
  • Start date Start date Nov 20, 2007
jhonda
125
Huntersville NC
Nov 20, 2007
  • Nov 20, 2007
I checked my fuel pressure today due to the lack of power and increased water temp....anyways intiall pressure at idle is 30psi if I rev it up it goes to 40....is this right or am I doing it wrong. Any imfo or ideas??
Thanks
Jason
bill302
2,131
alabama,gadsden
Nov 20, 2007
  • Nov 20, 2007
remove the vacuum line to the regulator and check pressure...it should read 38-40 psi with the vacuum line removed...do you heve an adjustable fuel pressure regulator?
cenok is family
1,409
69
79
Norman, Ok
Nov 20, 2007
  • Nov 20, 2007
BYRDPE
1,556
Memphis,Tn.
Nov 20, 2007
  • Nov 20, 2007
Does the vacuum line need to be plugged when setting fuel pressure?
jhonda
125
Huntersville NC
Nov 20, 2007
  • Nov 20, 2007
I do but it is not installed. I am just testing the orginal one. I know it is burning real rich at start up and sometimes at idle and everyonce and awhile when I get on it.
R
rossford
  • Nov 21, 2007
you have to ck the amount of fuel coming out also,a car low on gas can have good fuel pressure. engine running hot doz not sound like fuel, also ck back pressure,cloged cat maybe,timming,ect.
jhonda
125
Huntersville NC
Nov 21, 2007
  • Nov 21, 2007
well my car has a offroad x pipe. And timing is at 15degrees
white99gt
4,649
stockbridge,Ga(near atlanta)
Nov 21, 2007
  • Nov 21, 2007
How do you know its rich? Wideband?
A aftermarket fuel pressure regulator is a waste ,if the car is running properly its not needed.
I ran a stock regulator with a 255lph high pressure pumps and no "richness" and on my new combo im still running a stock regulator.
jhonda
125
Huntersville NC
Nov 21, 2007
  • Nov 21, 2007
black smoke, smell
white99gt
4,649
Nov 21, 2007
#10
  • Nov 21, 2007
  • #10
black smoke.Even if its running right you will see that sometimes at WOT.Smell doesnt mean its running rich,if it SMELLS rich its actually running LEAN..
jhonda
125
Huntersville NC
Nov 21, 2007
#11
  • Nov 21, 2007
  • #11
Im not saying your wrong but I have never heard that before, my 90f150 smelled rich burned rich I know because the exhaust would blow a steady blue flame out on the hwy if i dropped it from 4th to 3rd and stomped on it
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 22, 2007
#12
  • Nov 22, 2007
  • #12
Any setting or testing of the fuel pressure needs to be done with the fuel pressure vacuum line disconnected and the vacuum line plugged.
jhonda
125
Huntersville NC
Nov 22, 2007
#13
  • Nov 22, 2007
  • #13
well turned out to be the fuel pressure so far
I checked my fuel pressure with the stock regulator and it was running 44lbs of pressure. Put new regulator on adjusted to 40lbs and everything seems good so far
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
J
Fuel Fuel Pressure Issue
  • justadude07
  • May 12, 2025
Fox 5.0 Mustang Tech May 12, 2025
justadude07
J
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
