fuel pressure regulator
  • Thread starter Thread starter rock88gt
  • Start date Start date Sep 19, 2004
R
rock88gt
North Carolina
Sep 19, 2004
  • Sep 19, 2004
I've noticed a fuel leak under the thingy with the screw on top to adjust the fuel pressure(this is the correct way right?) Does any one know if this is a common problem with the regulators or what is underneath that and could be leaking...it's getting pretty bad, so far I've gotten about 60 miles to half a tank using premium
HISSIN50
34
129
Sep 19, 2004
  • Sep 19, 2004
it does sound like the regualator. have you pulled the vac line and checked it for fuel (when the diaphram inside the regulator goes, it can leak into the vac line)?
clean everything up and check it. i would NOT drive or run the car like this - that is a huge FIRE hazzard.
good luck.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Sep 20, 2004
  • Sep 20, 2004
good luck.
Good point. There is a seal from the regulator to the lines and then they can internally leak, many makes sell rebuild kits.
nito88stang
2,012
Fullerton, California
Sep 20, 2004
  • Sep 20, 2004
Could also buy a cheap fuel pressure gauge and put it on the shrader valve to test the system out and see if it holds pressure and if it adjust accordingly with vacuum.
N
NightStalkersSO
62
Gilbert, Az
Sep 20, 2004
  • Sep 20, 2004
60 Miles to half a tank? That means you're leaking around 5 gallons of gas for every 3 you use?!?!? Sounds like you're driving a bomb around! Park the car and order yourself a Kirban FPR and a gauge of some kind so you can tune it in....it sounds like along with the leak you're fpr is probably going out on you, I can't see you leaking that much gas....but I'm not there, so who knows! For your sake, I hope you're not
R
rock88gt
North Carolina
Sep 20, 2004
  • Sep 20, 2004
Thanks for the help guys. I took it to a mechanic(someone I know and trust) and he found a hole in the fuel rail where it had been rusted out. He said ford is known for having weak fuel rails. So I'm replacing both fuel rails and all the injector seals just in case. Thanks again
HISSIN50
34
129
Sep 20, 2004
  • Sep 20, 2004
im very glad to hear you took it to the mechanic - what he says sounds very possible. good man (you) for taking care of it so soon!
new injector O-rings and pintle caps are a great idea while swapping the injectors from one rail to another. the kits are around 3-4 bucks each (need 8 kits) from the local parts house (just to give an idea of cost). money well spent.
nice work and good luck.
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Engine 1990 5.0 bogs and pops over half throttle
  • Sander
  • Aug 1, 2025
Fox 5.0 Mustang Tech Aug 2, 2025
AeroCoupe
D
Fuel 1985 GT Fuel Line Diagram
  • DienstXIV
  • Apr 17, 2025
2K
Fox 5.0 Mustang Tech Jul 12, 2025
DienstXIV
D
  • dan50
  • Jul 18, 2026
dan50
