Fuel pressure rising at idle?
01' Bullitt
15
Canaduh
I've got a nexus fuel pressure gauge in my Bullitt (electric), normally reads 30psi at idle. The gauges have been in the car for half a year with no problems.
For the past week it has been rising at idle to 50psi gradually, RPM is constant and doesn't change. The pressure goes down after a long highway run. The car is usually hot (at operating temp) when the pressure is rising.
Also had CEL "Mass Evap leak detected" set, cleared last week, it has not set again.
Bad sender on the gauge or something else?
The PCM normally raises the fuel pressure to prevent the fuel from boiling in the rail when it gets hot.. just like pressurizing the coolant. I see anything from 30 to 50 at idle around here too.
Now, I don't know why you had a CEL light earlier, but I think it's just an amazing coincidence that you noticed the normal fuel pressure fluctuation around the same time.
Thanks for the info. I've been told that the "Mass Evap leak detected" is related to a vaccum leak (most likely gas cap). It was pretty strange that the CEL came on because the car was running great. I was wondering if anything had changed and then I started to see the Fuel pressure gauge go red (warning me of something).
Good to know it's all normal, it's been extremely hot these past two weeks here so it all adds up.
Thanks again.
