I have a 80mm Vortech MAF body, stock MAF, 30# injectors and 8A001-026 (.562) sample tube. My engine is supercharged and has GT40p heads, explore intake, and 70mm tb.
I did a belt off (no boost) Wide band A/F ratio check with base fuel pressure at 42#. Cold startup A/F was 18-20. This went to 14.7 when the O2s warmed up. A/F was 14-15 though the RPMs with this setup.
I decided to raise the fuel pressure a few times. I am now at 66# A/F atcold startup idle is 16-18. A/F is 13-13.5 through the RPMs with some 14 spikes.
Is this amount of fuel pressure normal or is my MAF broken?
