fuel pressure
  • Thread starter Thread starter Beasly B
  • Start date Start date Jan 23, 2006
Beasly B
165
Virginia
Jan 23, 2006
  • Jan 23, 2006
Just want to say thanks to a couple of guys that helped me last week on some codes that I was dealing with. I replaced the evp sensor, ect sensor, cleaned the maf sensor, and adjusted the tps sensor, it fixed my problem and no more check engine light. I just got a fuel an adjustable fuel pressure regulator, looking at my sig, what fuel pressure should I run?
04sleeper
2,674
14
89
Dallas, TX
Jan 23, 2006
  • Jan 23, 2006
For right now I would start around 36-38 psig with the vacuum disconnected NA with 30 lb injectors.
42-45 psig with the ATI with 42 lb injectors and no FMU.
Every car is a little different but this should give you a good start.
willys1
1,004
New Jersey
Jan 23, 2006
  • Jan 23, 2006
nice mods A dyno tune would tell you exactly whats best..Like 04sleeper said,every motor is different..My motor (at the track) performs best at 32-34 lbs..Only when its warm though,soon as it gets cold out its hard to start up so I put it at 38lbs.
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
