fuel pressure
Beasly B
165
Virginia
Just want to say thanks to a couple of guys that helped me last week on some codes that I was dealing with. I replaced the evp sensor, ect sensor, cleaned the maf sensor, and adjusted the tps sensor, it fixed my problem and no more check engine light. I just got a fuel an adjustable fuel pressure regulator, looking at my sig, what fuel pressure should I run?
For right now I would start around 36-38 psig with the vacuum disconnected NA with 30 lb injectors.
42-45 psig with the ATI with 42 lb injectors and no FMU.
Every car is a little different but this should give you a good start.
nice mods :nice: A dyno tune would tell you exactly whats best..Like 04sleeper said,every motor is different..My motor (at the track) performs best at 32-34 lbs..Only when its warm though,soon as it gets cold out its hard to start up so I put it at 38lbs.
