Fuel Pressure
  • Thread starter Thread starter B-radster
  • Start date Start date May 19, 2014
  • 3
  • 4
First Prev 4 of 4
madspeed
Colonel Mustard
1,332
204
a van down by the river
May 19, 2014
#61
  • May 19, 2014
  • #61
its usually tucked down in there pretty good
madspeed
Colonel Mustard
1,332
204
May 19, 2014
#62
  • May 19, 2014
  • #62
actually,one of those is the single wire, hang on, i'll pull a schematic
madspeed
Colonel Mustard
1,332
204
May 19, 2014
#63
  • May 19, 2014
  • #63
here ya go. check it over and you should be able to determine which wire it is
madspeed
Colonel Mustard
1,332
204
May 19, 2014
#64
  • May 19, 2014
  • #64
mine was rigged like yours from a previous owner. My bet is theres only one wire that is loosley inserted into the connector, and that will be it
Reactions: B-radster
B-radster
80
Grass Lake, Michigan
May 19, 2014
#65
  • May 19, 2014
  • #65
Thanks for the schematic. That will help. Theres alot of wiring missing on this car. I had to rewire the headlights blinkers and horn already too.
B-radster
80
May 19, 2014
#66
  • May 19, 2014
  • #66
They are all rewired and just shoved into the plug and were taper into the "eec" cover. Those top 2 slots in diagram are empty right now. That "spout" tip helped alot earlier. It fell right in with that thing removed. Was erratic when i plugged it back in for the first minute then settled right down. Its set at 12 btc for now cant get much more because the ignition module is just about touching the tstat neck. i redid the TPS properly too its now at .934
madspeed
Colonel Mustard
1,332
204
May 19, 2014
#67
  • May 19, 2014
  • #67
someone had a field day with her huh?
B-radster
80
May 19, 2014
#68
  • May 19, 2014
  • #68
Someone who didn't know unfortunately.
B-radster
80
May 19, 2014
#69
  • May 19, 2014
  • #69
Not quite sure what they were attempting to do? Not like taking out horn and headlight wire weight will drop your 1/4 time a whole lot!
madspeed
Colonel Mustard
1,332
204
May 19, 2014
#70
  • May 19, 2014
  • #70
because racecar
B-radster
80
May 20, 2014
#71
  • May 20, 2014
  • #71
That single wire is no where to be found! Lol
madspeed
Colonel Mustard
1,332
204
May 20, 2014
#72
  • May 20, 2014
  • #72
your images show 4 wires in the connector. Wire diagram only calls for 3. the 4th is the mising single wire
B-radster
80
May 22, 2014
#73
  • May 22, 2014
  • #73
Wouldnt there be 6 wires shown here?
  • 3
  • 4
First Prev 4 of 4
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
Engine Misfire below 3K RPM
  • foxbodyclark
  • May 25, 2025
Fox 5.0 Mustang Tech May 31, 2025
General karthief
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
