Installed a 255 in-tank yesterday and car ran fine. Drove it 10 miles today with no problems. Jumped in tonight and hit the key and she won't start. Checked my fuel pressure guage and it's at 0. No fuel pump sound when key is turned either.
Question is: Is there a relay or fuse I could check first before dropping the tank again? I checked the inertia switch and it's fine. Thanks for any help!!!
. The fuel pump relay is under your MAF on the passenger side strut tower, make sure you have power coming in and out of the relay with the car turned on.
I think? Is it the 4 wire box (2 of them) that lookz like it's capped? I already hit the key and tested them with a test light. One box has power on 2 wires and the other only has power on one. Don't know what to do? Which one is the correct one to check?
I knew the A/C had a kill at WOT, now I know which relay it is... Thanks alot brother!!!
