Fuel pump doesn't work, also can not pull codes
Killercanary
The car that set the bar.
Altoona, PA
We're having trouble with my dad's '91GT. He was getting ready to have the engine bay painted and I talked him into hidding wires. Well, that has proven to be a bad idea as the car hasn't started for over a month now. When the key is turned forward, the fuel pump doesn't start. I've downloaded every wiring diagram I could get my hands on and we have checked and replaced both fuel pump relays (the on under the driver's seat and the one in the passenger side fenderwell) and the EEC power relay located above the computer. I put a meter on the old and new relays and the results are the same. On the FP relay under the seat, when the key is in the on position I have power to all wires except the green/yellow power wire that according to the diagrams I have goes to the fuel pump. At the FP inertia switch I'm getting a power reading with the key on, but it's only showing about 5 volts. I forgot my paper at my dad's that I listed the colors of the wires on, but the relay in the pass. side fender only had key on power in two fo the 4 wires there.
The other and I fear more serious problem is that we tried to pull the codes with a handheld code reader, when the key is switched on the reader usually beeps and the light flickers on it and then the codes start to come out. Now when the key is on the light goes dim and nothing else happens.
When hooking up all the hot wires we accidently put one to ground. This shouldn't have done anything bad as putting a ground to power would have.
So at this point we're out of ideas. I'm now fearing tha something is shorted in the EEC. I don't know how to test it. I read online that if the injector has power with the key on the EEC is good, but I believe that isn't true since I also read that the EEC activates various things by grounding the circuit. If this is the case then the injector should have power and the EEC would act to ground it to fire the injector.
I appreciate any and all help. I'll post back later with which color of wires had voltage and which did not.
The computer has its own dedicated power ground that
comes off the ground pigtail on the battery ground wire. Due to
it's proximity to the battery, it may become corroded by acid
fumes from the battery. It is a black cylinder about 2 1/2" long
by 1" diameter with a black/lt green wire.You'll find it up next to
the starter solenoid where the wire goes into the wiring harness
Fuel Pump Troubleshooting for 91-93 Mustangs
Clue – listen for the fuel pump to prime when you first turn the ignition switch on.
It should run for 5-20 seconds and shut off. To trick the fuel pump into running,
find the ECC test connector and jump the connector in the lower RH corner to
ground.
attachment.php
If the fuse links are OK, you will have power to the pump. Check fuel pressure –
remove the cap from the Schrader valve behind the alternator and depress the
core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be
used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch
cars hide it under the plastic trim covering the driver's side taillight. Use the
voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built
before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect
for fuel escaping while pump is running.
The electrical circuit for the fuel pump has two paths, a control path and a power
path.
The control path consists of the computer, and the fuel pump relay coil. It turns
the fuel pump relay on or off under computer control. The switched power (red
wire) from the ECC relay goes to the relay coil and then from the relay coil to the
computer (light blue\orange wire). The computer provides the ground path to
complete the circuit. This ground causes the relay coil to energize and close the
contacts for the power path. Keep in mind that you can have voltage to all the
right places, but the computer must provide a ground. If there is no ground, the
relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like
fuses, except they are pieces of wire and are made right into the wiring harness.
The feed wire from the fuse link (pink/black wire) goes to the fuel pump relay
contacts. When the contacts close because the relay energizes, the power flows
through the pink/black wire to the contacts and through the dark green\yellow
wire to the inertia switch. The other side of the inertia switch with the
brown\pink wire joins the pink/black wire that connects to the fuel pump. The fuel
pump has a black wire that supplies the ground to complete the circuit.
Remember that the computer does not source any power to actuators, relays
or injectors, but provides the ground necessary to complete the circuit. That
means one side of the circuit will always be hot, and the other side will go to
ground or below 1 volt as the computer switches on that circuit.
diagram of the wiring for 91-93 cars.
Power circuits:
Power feed: Look for 12 volts at the pink/black wire (power source for fuel pump relay).
No voltage or low voltage, bad fuse link, bad wiring, or connections. Remember that on 92
or later models the fuel pump relay is located under the Mass Air meter. Watch out for the
WOT A/C control relay on these cars, as it is located in the same place and can easily be
mistaken for the fuel pump relay.
Relay: Turn on the key and jumper the ECC test connector as previously described. Look
for 12 volts at the dark green\yellow wire (relay controlled power for the fuel pump). No
voltage there means that the relay has failed, or there is a broken wire in the relay control circuit.
Inertia switch: Check the brown/pink wire, it should have 12 volts. No 12 volts there, either
the inertia switch is open or has no power to it. Check both sides of the inertia switch: there
should be power on the dark green\yellow (inertia switch input) and brown/pink wire
(inertia switch output). Power on the dark green\yellow wire and not on the brown/pink wire
means the inertia switch is open. Press on the red plunger to reset it to the closed position.
Sometimes the inertia switch will be intermittent or will not pass full power. Be sure that
there is 12 volts on both sides of the switch with the pump running and that the voltage drop
measured across the switch is less than .75 volts.
Control circuits:
Relay: The red wire for the fuel pump relay coil gets its power feed from the ECC relay.
No 12 volts here, and the ECC relay has failed or there is bad wiring or bad connections
coming from it. The ECC relay is located on top of the computer, which is under the passenger’s
side kick panel. It is not easy to get to, you must have small hands or pull the passenger side
dash speaker out to access it.
Relay: The light blue/orange wire provides a ground path for the relay power. With the test
connector jumpered according to the previous instructions, there should be less than .75 volts.
Use a test lamp with one side connected to battery power and the other side to the light blue/orange
wire on the fuel pump relay. The test light should glow brightly. No glow and you have a broken
wire or bad connection between the test connector and the relay. To test the wiring from the
computer, remove the passenger side kick panel and disconnect the computer connector.
It has a 10 MM bolt that holds it in place. Remove the test jumper from the ECC test connector.
With the test lamp connected to power, jumper pin 22 to ground and the test lamp should glow.
No glow and the wiring between the computer and the fuel pump relay is bad.
Computer: If you got this far and everything else checked out good, the computer is suspect .
Remove the test jumper from the ECC test connector located under the hood . Remove the
plastic cover over the computer wiring, but leave the computer wiring connector plugged
into the computer. With the ignition switch in the run position, connect a test lamp to the
battery and back probe pin 22, the light blue/orange wire with it. The lamp should glow
brightly. No glow and the computer has died a sad death. :( If you used a voltmeter instead
of a test lamp, you should see battery voltage, whatever that may be…
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Fuel pump runs continuously: The light blue/orange wire has shorted to ground. Disconnect
the computer and use an ohmmeter to check out the resistance between the light blue/orange
wire and ground. You should see more than 10 K Ohms (10,000 ohms) or an infinite open
circuit. Be sure that the test connector isn’t jumpered to ground.
Uhh...how do you figure? any time you have power + ground, you will have problems. depending on the wire, it is possible that you blew out the fuse link for the entire eec system. but jrichkers diagram will help you figure it all out.
Paul, I can't help like JRichker can, but a couple things came to mind (much of which JR already stated).
There should only be one FP relay. It's either under the driver's-seat or next to the WOT relay (passenger fender, kinda' under the air inlet tube). The relay was moved from under the seat to the fender late in the aero fox run, but there's only one relay. The WOT relay is under the air inlet on all aero foxes.
Paul, in your second to last paragraph, I think it's true if adding one word: If the injectors show 12 volts, it indicates that the EEC *relay* is working. You are correct that the computer sends ground to excite the injectors. I think what you read might make more sense now.
JR has gone to a lot of work to make his master checklists, and going down them top-to-bottom is key. Personally, a point or two of emphasis for me would be:
Check the inertia switch for voltage drop across the terminals. Seems to me that the inertia switch should be battery voltage, not VREF.
Because of the issues, I'd want to closely examine the self-test connector wiring (since it also relates to the fuel-pump relay's grounding pathway, as well as code retrieval).
And maybe it will be as simple as a bad fusible link though......
Good luck and bump off page two for ya Paul.
When I read threw your thread I didnt see you mention if you cheched the power disrupter relay in the trunck by the driver side rear light.
The relay that cuts power to the fuel pump in the case of a rear end collision.
I had to reset it before with no exsplanation as to why it shut off.
that's the inertia switch, and yes he did
Sounds like your losing power between the relay and the inertia switch. Could be one of the female connectors in the realy base is not making good connection. Here is a tip that will tell if you have any "power" behind the 5volts. Use the multimeter and get a good 5v reading, then use a 12v tester that has a light bulb in it and check the voltage with the mutlimeter probe on the 12v tester metal shaft - if the voltage is lower than with just the multimeter, there is most likely a bad connection in the sockets or wiring connections.
