  • 1994 - 1995 Specific Tech
Fuel Pump help
  • Thread starter Thread starter wytstang
  • Start date Start date Oct 14, 2005
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Oct 14, 2005
  • Oct 14, 2005
I started to swap out pumps today that turned out to be a huge pain in my butt. Any who I just test drove the car and now it's breaking up pretty bad past 4g's. I looked at the diagram(sp?) that was sent with the pump and noticed it had a line that looked to be pluged. There are two lines actually on the assembly that has one pluged and the other unplugged (return line). I don't remember pluging the other line, could this cause my car to break up pretty bad???
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 14, 2005
  • Oct 14, 2005
I would like to help Danny but it has been so long since I did that stuff to mine I just don't remember any of the details.
A hose that is plugged sounds strange to me however.
I don't remember any of that, lol.
Grady
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 14, 2005
  • Oct 14, 2005
Grady at least you tried
On the assembly itself it has 3 open metal lines. One uses the S hose that goes to the pump itself. The second one has no lentgh to it at all I believe it is the return line. The third line is near the pumps power source (on top of the pump) when installed that one I'm almost 100% needed to be pluged. I found an orange vacumm plug near the car were I was working. It matches the same one (style wise) in the picture that came with the new pump. I think it's called the pick line??? I doubt it's supposed to suck air like it's doing right now.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Oct 15, 2005
  • Oct 15, 2005
i will go out later today (cause it's 6 am here) and dig myold pump assy out, i have a good idea what your talking about with plugging the lines. the holley i bought was already done i pulled my old one out and put the new one in ! I'm kinda lost on the 3 metal line stuff tho? peace
john
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 15, 2005
  • Oct 15, 2005
Here the diagram
You can see the plugged line, it was pluged by an orange plug. Well I just finished plugig the line and it went to 60+psi with vac on . I have no clue were to go from here. It was simple the last time I did it this one has turned out to be a nightmare(sp?).
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Oct 15, 2005
  • Oct 15, 2005
Good luck Danny.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Oct 15, 2005
  • Oct 15, 2005
Yeah I searched on corral and here and didn't find anything. Hopefully someone here can let you know.
Scott
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 15, 2005
  • Oct 15, 2005
Thanks for trying man I'm pretty much done with it I'm all out of ideas. I'm just going to get one of my Ford buddys here to help out or just pay him. I just don't have the time to keep dropping it/jacking it up then messing with it (stupid job). I'm going to give it another try tomorrow after noon when I get off of work. If any one has any ideas feel free...
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Oct 15, 2005
  • Oct 15, 2005
Move to Clearwater, then you can bribe Chad to do it with Whoppers
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 15, 2005
#10
  • Oct 15, 2005
  • #10
Yeah I really wish I still had Chad here. But I still have some Ford techs to rely on, that can help me out when they have a moment to spare.
HISSIN50
34
129
Oct 15, 2005
#11
  • Oct 15, 2005
  • #11
Danny, It sounds like your return line is capped. SO you are running off raw pump (no regulation).........
I just looked in the manual and see only the two lines. It does not show the lower line in your pic in my pic.......
Not that this helps. So do you have two complete lines connected with no plugs? The 3rd (lower) line might be a continuation of one hose and we dont even deal with it normally...........
I do think your return might be plugged.
Good luck bud.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 15, 2005
#12
  • Oct 15, 2005
  • #12
Okay new info (thanks to marius of corral) that orange plug is not a plug at all. It's a rubber baffle that "relys on a certain amount of fuel return so that the gas being run through the pump will help keep it cool. By plugging that line you will just build up fuel pressure and burn your pump up". That explains the 60+psi's at idle with vac on, and when I left it with out the plug the lack of power in the upper rpm's.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 15, 2005
#13
  • Oct 15, 2005
  • #13
Good luck bud.
Bingo that (what I thought was a plug) is a rubber type of baffle . So now I have to wait until Monday to hit up Ford for the peice and hopefully the rubber baffle is sold seperatly and I don't have to buy the whole unit. I thought the other line in the pic was the return line not the one I was plugging.
JT the Hanes manuel has an almost exact pic of the one I posted...1st line is the return line, and right across from it is the other line (has no lenght), and the third the pump gets hooked up too.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Oct 15, 2005
#14
  • Oct 15, 2005
  • #14
Glad you figured it out. good luck finding the part. Napa or carquest might have it if they don't.
Scott
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 15, 2005
#15
  • Oct 15, 2005
  • #15
It makes sense now that know that's not a plug. This should clear things up I hope...
HISSIN50
34
129
Oct 16, 2005
#16
  • Oct 16, 2005
  • #16
Danny, nice work. I will look in Haynes and see what they show (I was lookin in the factory manual).
It has to feel good to have figured it out!
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 16, 2005
#17
  • Oct 16, 2005
  • #17
Real good and a huge thanks to marius of corral.net for knowing that little rubber peice is a baffle and not a plug like I assumed it was. I'm just hoping one of the Ford techs has a fuel unit laying around with the orange baffle still attached. If not I may be forced to buy the entire unit (minus the pump) to fix mistake.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 17, 2005
#18
  • Oct 17, 2005
  • #18
O.K well that didn't fix it I pretty sure it's someting else now, I have one of my Ford buddys coming over after work I'm all out of ideas.....
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 18, 2005
#19
  • Oct 18, 2005
  • #19
Okay cleared codes a few days ago to see what else was causig the poor performance. Ran codes today and 113 popped up ACT/IAT/VAT circuit above max voltage -40 F indicated. So I went ahead and ordered an ACT sensor from Ford. Since it helps control fuel ratios and timing curves it explains the "popping" in the exhaust ocasionally(sp?) and poor pwoer in the upper rpms. Hopefully this will clear up al my problems.
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
