  • 1994 - 1995 Specific Tech
Fuel Pump Installation, Help please...
  • Thread starter Thread starter oxemoron
  • Start date Start date Sep 16, 2005
O
oxemoron
94
  • Sep 16, 2005
Hey guys yesterday i started installing the new fuel pump with my friend. Everything went smooth but now we cant get the new fuel pump to sit all the way in the tank and have the top of the pump seal nicely with the tank. Were very confused cause when i went to pep boys they asked if my car was from 4/94 and up or if it was older. Then i went to napa which is where i ended up buying it and they only had one pump listed and i got that. Could it be possible that the pump is wrong? we looked very close at the two and they looked identical. The tank is not entirely down, one side is dropped and the other side is still suspended by the pipe which fuel is poured in. Sorry if i dont sound like i know what im doing, cause i kind of dont. my friend is the mechanic, im just trying to figure out the problem
95Vert
1,785
North Mexico (deep south Texas)
Sep 16, 2005
  • Sep 16, 2005
Dude, I had the same problem but it's not the pump. The whole assembly has to sit in the middle of a little "compartment" inside the tank and you have to twist and turn it until it goes in. Be sure not to bust a line or anything, but it does involve some hand work. Bring the whole tank down and you'll have better access.
wildmandave
70
largo,FL
Sep 16, 2005
  • Sep 16, 2005
He's right theres a place where the sock at the end of the pickup tube is supposed to go and it only fits one way. Get a flashlight and shine in there and this should give you a better idea of how it goes in but don't force it or it may break!
Black95GTS
1,644
Marlborough, MA
Sep 16, 2005
  • Sep 16, 2005
subscribing, i just ordered a new fuel pump, please post back if you get it resolved and have tips for the install!
thanks,
Adam
O
oxemoron
94
  • Sep 16, 2005
hey thanks guys, i was figuring there must have been some kind of compartment inside. i'll drop the tank and take a look, hopefully that should get things done.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 16, 2005
  • Sep 16, 2005
Yes, upon dropping the tank you will see the solution
Check in the "Official How To Thread" at the top of this 94/95 forum for a fuel pump writeup/tips.
Good Luck
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
New fuel pump relay
  • Scrapla347
  • Nov 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 8, 2025
Scrapla347
U
No fuel pump relay in harness
  • Uli661
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
Uli661
U
