I did a search and went through a few pages but there is too much information that doesn't fit my scenario.
Lets see... Car ran fine, drove to work. Tried to start it when I left and the starter cranks but the motor doesn't fire.
I decided to move the key to the accessory position and give the pump a second to prime but I can't hear the pump at all.
I remembered you can run the pump by grounding a wire on the eec diag. so I tried that. At least I think you ground it?
So I know my problem is caused by the pump not running.
The pump was changed less than a year ago. What should I try when I go to the car tomorrow?
I have no knowledge of the pump wiring. I know to check the inertia switch and someone told me that it may be inline to the pump and I could try to power the pump directly from there. Also someone said the fuel filter could be my problem?
Thanks ahead of time
