okies I am fed up, my car is a 92 4cyl. mustang convertable, now this is my problem everytime my engine gets hot, the car won't turn on after it's turned off and well also sometimes it stalls. I replaced the fuel pump and the stalling got a little better, however it is not really fixed. I've seen aftermarket products that wire around it, but that means that the fuel pump get's full 12V all the time when the engine is turned on, I dunno if the ecm(icm) or ecu is supposed to adjust the voltage on that fuel pump, however I do know the dam relay is inside the ecm(icm) now I look at that black box and well it doesn't look like it opens up. so here are my alternatives:
A. crack open that box somehow
B. find a nice little relay socket (I got like five wire harnesses from other cars sitting around so I should be able to find one and then just relay the fuel pump directly from the battery and wire it directly into a switched line and then the battery and on the other end the inertia switch. (would still be safe from accidents), but otherwise the ecu would lose control over the fuel pump.
What do you guys think?
terramir
terramir
to all of you that helped.
