SN95 Fuel Pump Problem-e85
Blue ovel
So I have a 95 gt and I put a stealth 340 intank pump. I'm running e85 and when I tried to start the engine I noticed that I didn't have fuel pressure. So I dropped the tank to inspect the pump and found it burnt up. I have a good ground. Voltage around 12.5. I took the stock fuel pump and put it back in it primed once and then it was burnt to. Any help and be appreciated thank you.
What model 340 did you have? 11540 is the proper e85 pump, previous versions arent quoted for e85 from what I understand,
How old was your aeromotive pump? They have a 1 yr warranty,
There are a couple e85 guys on here so they may have more insight for you,
I had same pump 11140 melt down in same spot, put in the 111540,
The new pump is acting fine.
I run 93 but we have allot of corn in our gas here,
You either have an e85 pump issue or power issue,
Have you check your resistance on the pump power lines? just a thought...
Could it be a possibility that he is airating the pump and running it dry and that's how it's burning up ? Maybe the stock tank vent isn't good and it's building too much pressure causing a vapor lock ?
I had zero issue with the 340 I had in my stock tank and it went into another blower car after mine with no issue.
