fuel pump problem
cervinisgt
120
iowa
this is not on a mustang. It is on my 2002 blazer xtreme. Last week my fuel pump went out. It has been very loud and i knew it was going to go. When it went out we beat on the tank and it started. I bought a pump off e-bay. They clamed it was a delco part but today when i got it i determined that it wasnt. I put the pump in and started it up. I drove about 5 min and shut it off. Went to start it and nothing. Figureing it was because it was a junk aftermarket pump i went and bought a new delco pump for $400. Put that in and just before i tightened the straps i tried to start it. Nothing. We shook that tank and then it started. Thinking it was just something to do with no ground (becuse the straps where loose) we finished the job. started it several times and then went up town. I stopped at a gas station and shut if off. started it right back up. Everything was working fine. Filled it with gas and then it wouldnt start. The relay is clicking and is 100% fine. what could be the problem
thanks
A Blazer forum will probably yield an answer in like 2 seconds. On older blazers (OBD-I), the control side of the FP relay went through the oil pressure switch. So if that switch went haywire, it could lead to issues.
Good luck.
