Fuel Pump problems
  • Thread starter Thread starter Gixxer750
  • Start date Start date Aug 9, 2004
Gixxer750
789
Saint John NB, Canada
Aug 9, 2004
  • Aug 9, 2004
Ok I am one of those guys that always turns the key and waits for the fuel pump to prime before I start my car. Last few days the pump primes but not as loud as it normally is. If I turn the key off and back on, it eventually gets as loud as it normally is. usually 3 key turns to get it sounding the way it always did. If I try to start off a weak prime, it takes a lot longer cranking over. Does this mean my fuel pum is on the way out??
Thanks
HISSIN50
34
129
Aug 9, 2004
  • Aug 9, 2004
stick a FP gauge on it and see what is goin on. you could also have regulator or check valve issues. good luck.
D
dromeda
146
  • Aug 9, 2004
Check the voltage after the inertia switch also. My friend's was really quiet. Found that it was only getting 6.5 volts (also explains his low fuel pressure problems).
Also as the pump fills with fuel it tends to quiet. 'Course you're seeing the exact opposite...
HISSIN50
34
129
Aug 9, 2004
  • Aug 9, 2004
the inertia switch is in series on the wire that goes to the FP relay, acting only as a relay coil. it either has enough juice to energize the relay or does not.
the wire from the solenoid (with fusible link) to the relay, and the exiting to the pump, is the wire that carries all the load to power the pump.
Gixxer750
789
Aug 9, 2004
  • Aug 9, 2004
So this switch is under the drivers seat with the relay? or is it on the pump itself??
thanks
HISSIN50
34
129
Aug 9, 2004
  • Aug 9, 2004
thanks
the inertia switch is in the trunk - near a light assembly's plastic shrouding. it should have a plastic pop off cover on it (ive never found mine, and it is probably different, since it is a vert). many have posted where it is before, in case you feel like searching.
good luck.
88hatchblack
163
Willard, Ohio
Aug 9, 2004
  • Aug 9, 2004
the inertia switch is in the trunk or hatch on the driver's side. there should be a gromet on the plastic panel that you will need to take out. the panel is on the very back on the drivers side next to the trunk latch. the interia switch is kind of a black rectangle with a small white button switch on top. check the voltages of the red/black wires there.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
