  • 1994 - 1995 Specific Tech
Fuel Pump Q?
  • Thread starter Thread starter MossDaHaus
  • Start date Start date Oct 20, 2005
M
MossDaHaus
11
Brighton, MI
Oct 20, 2005
  • Oct 20, 2005
So I have a 94' with 95k on it and im wondering if my fuel pump is going. if you turn the key, the fuel pump is puttin off a low pitched sound instead of the higher pitched sound it use to. the engine will turn over but wont start. i tried turning on and off the key a few times and then itll start and run for like a minute then die. Anybody know if it is the fuel pump or possibly a grounding issue?amnit:
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Oct 20, 2005
  • Oct 20, 2005
Check your fuel pressure pick up a gauge. If it reads below 30psi while idling with vaccum on it's weak (needs replacing). Also turn the car off and see how long it takes to drop fuel pressure. If it drops rapidly your pump is unable to hold fuel pressure and needs to be replaced. Start with the cheapest item to replace......fuel filter
M
MossDaHaus
11
Brighton, MI
Oct 20, 2005
  • Oct 20, 2005
Well i would check it if it would start but it wont start...and i just changed my fuel filter. anyone else?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 20, 2005
  • Oct 20, 2005
It will still prime the fp with the key on, or even with the car turning over a few times. Good luck
M
MossDaHaus
11
Brighton, MI
Oct 20, 2005
  • Oct 20, 2005
okay thanks
HISSIN50
34
129
Oct 20, 2005
  • Oct 20, 2005
Agreed with Danny. Toss a gauge on it and note priming, cranking and idling (when it does) pressure. as it just about stops idling on its own, note if pressure has just taken a poop on you.
FWIW, the tank is not totally empty right? The pitch also changes when one is about out of fuel.
Good luck.
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
