Fuel pump question
  • Thread starter Thread starter crushnut
  • Start date Start date Jul 29, 2004
crushnut
870
Oregon
Jul 29, 2004
  • Jul 29, 2004
I am currently switching from my current 2bbl intake and carb to a 4bbl Edelbrock and stealth intake, and am wondering if i can use the fuel pump that i had for the 2bbl?(temporaily of course) If not what fuel pump do you guys recommend?
Thanks
66P51GT
721
Cerritos, CA
Jul 29, 2004
  • Jul 29, 2004
There is no difference in stock 289 fuel pumps for 2bb or 4bb carbs. You should be fine - even if for a long period of time. Where you might run into problems is if the stock pump can't keep up with any other modifications you have made made to your engine. These would be most prevelant in high RPM situations where you can starve the carb of fuel and start running lean.
If you aren't going too wild with your engine mods, just get a Holley street pump that has a constant flow and rated at 6psi. If you get a race pump, it will require a pressure regulator and is overkill for a mild street engine.
$.02
crushnut
870
Oregon
Jul 29, 2004
  • Jul 29, 2004
$.02
Cool, thanks
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
  • Mindseye007
  • Aug 16, 2026
Mindseye007
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
