Fuel Pump Question
WQRed50
24
Burnham, IL
This Winter I am going to replace the gas tank, sending unit and fuel pump in the 90 GT Vert. At 1/4 tank when I go around a left hand corner the engine stumbles, my sending unit hasn't worked in about 6 years and this Summer, at about 4,000-4,500 the engines seems starved for fuel.
Question - What fuel pump should I go with? 110 lph, 155lph or 190 lph?
I plan very little future mods to this car since my daughter is taking it to college next year. Currently we have a K&N filter, 70mm throttle body, 19lb injectors, headers, hi-flow cats, 2-chamber muffler, 3.73 gears, Lentech trans with shift kit. The valves were seated and some minor head work done last spring. If anything, I will be giving it a good tune up, replumbing the vacuum system and putting a fuel pressure gauge in it.
Thanks!!
I would look closely at the baffle inside the fuel tank. If it has broken loose, it would allow fuel to slosh away from the pump pickup. That would casue the pump to suck air and lose pressure.
Two very good replies above. I'd add that a Walbro (Or a repackaged Walbro - half the brands out there repackage Walbros) is the way I'd go. I'd buy from a reputable vendor due to the aesthetically pleasing knock-offs out there.
Good luck.
Many thanks!
Thanks for the replies and the info.... I'll be looking to replace the stock pump with a 110lph unit. I normally use 5.0Resto for my parts and they have a couple of good brand names there.
Thanks again!
