  • 2.3L (N/A & Turbo) Tech
fuel pump question
  • Thread starter Thread starter stykthyn
  • Start date Start date Sep 10, 2007
First Prev 2 of 2
sublimefool311
#21
  • Sep 16, 2007
  • #21
I know that there is a relay for the fuel pump (I had the same problem as the initial poster), and I see from previous posts that it also houses relays for the A/C and fan. Anybody know what else is controlled by this beast?
stykthyn
5,232
2,652
223
gainesville
Sep 17, 2007
#22
  • Sep 17, 2007
  • #22
the relay is running for the moment, but if it craps out again will there be a negative impact from running a jumper wire to the green/yellow wire so there is a constant power feed? that way the pump will run with the key on?
SILENTCARL
40
#23
  • Sep 17, 2007
  • #23
I had mine jumpered (not a word I know...), and didn't see anything bad happen, but I don't know for sure. Remember that it is relatively high current... If you want it to come on with the key you will want to use a relay. You wont be able to control prime or similar functions.
That relay module controls:
A/C Clutch
Fan
EEC Power
and
Fuel Pump
stykthyn
5,232
2,652
223
gainesville
Sep 18, 2007
#24
  • Sep 18, 2007
  • #24
I could run the jumper to a relay that is only hot at key on, such as the ignition harness
First Prev 2 of 2
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
D
Fox 88 foxbody no power to red and black wire at fuel pump relay
  • drod88
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
Mcmahst
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
U
No fuel pump relay in harness
  • Uli661
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
Uli661
U
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 4, 2026
manicmechanic007
