superstroke17 New Member Jun 21, 2007 79 0 0 Greenville, SC Jan 31, 2008 #1 Jan 31, 2008 #1 Will an aftermarket fuel pump like a 190-255 lph be ok with a stock engine. Thanks!
BK_CAULEY it's built for speed not longevity, woman Dec 26, 2006 0 10 49 Thomasville, ga Jan 31, 2008 #2 Jan 31, 2008 #2 sure it will. it might up the fuel psi some but the ECU should judt cut back on the injectors duty cycle. and if you see that its upping the fuel psi to much to can always get a fuel pressure regulator.
ttop88 Member Mar 12, 2007 42 0 6 indiana Jan 31, 2008 #3 Jan 31, 2008 #3 It will be fine. Extra fuel will go back to the tank through the return line. Your fuel temp will go up do to the constant circulation tho.
