fuel pump question
  • Thread starter Thread starter santos
  • Start date Start date Sep 28, 2018
santos
362
Camp Hill, PA
Sep 28, 2018
  • Sep 28, 2018
Need to replace fuel pump in my 92 bolt on. I have heard different people tell me that I need to upgrade regulator, and others say stock is just fine. what is stangnets opinion on this? plan on putting walbro 255 in the tank
thanks
Steel1
Mustang Master
Aug 18, 2017
1,419
639
143
Connecticut
Sep 28, 2018
  • Sep 28, 2018
Stock regulator is fine.
I still run a stock regulator on my 393w.
Dan02gt
mazing how much gas smell came from that tiny hole
20+ Year Stangneter
Mar 2, 2003
909
415
113
Greenville, NC
Sep 28, 2018
  • Sep 28, 2018
The stock regulator will be fine. When you say 92 bolt on. Do you mean the car has basic mods? If so the 255 is way over kill.
santos
362
Camp Hill, PA
Sep 28, 2018
  • Sep 28, 2018
every bolt on, except heads and cam ( coming later) got a better suggestion? I did assume a 255 is overkill, but that what I have been hearing to put in
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,085
224
Massachusetts
Sep 28, 2018
  • Sep 28, 2018
255 is overkill. 150 or even 190 would be more than enough.
When I went from a 88lph to a 190, my fuel pressure went up 3-4 PSI. Fortunately I had a kirban adjustable so I was able to lower it down, however the lowest setting possible gave me 39psi. That's just my experience.
If I could of it again, I would install a 150lph pump, and that's with my future plans of TFS170 heads. I feel it's more than enough short of a power adder on the combo
Dan02gt
20+ Year Stangneter
Mar 2, 2003
909
415
113
Greenville, NC
Sep 28, 2018
  • Sep 28, 2018
I'm still running the stock pump on my H/C/I setup. However, I know I'm past the limit of the pump and will be installing a 155 Walbro this weekend. I would recommend you do the same. No need to be pushing that much fuel through the system when you don't need it.
santos
362
Camp Hill, PA
Sep 28, 2018
  • Sep 28, 2018
thanks for the input , I appreciate it
Blown88GT
2,283
524
164
Palm Beach Gardens, FL
Sep 28, 2018
  • Sep 28, 2018
The 255 is good for up to 450hp.
http://www.eastcoastrollingthunder.com/jmiller/finject1.htm
Boostedpimp
20+ Year Stangneter
May 8, 2003
1,451
493
154
NJ
Sep 28, 2018
  • Sep 28, 2018
Have ran the 255 on various cars that needed it and didn't need it and never had a problem
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
New fuel pump relay
  • Scrapla347
  • Nov 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 8, 2025
Scrapla347
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
getting 90 PSI at fuel rail - help
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
