Fuel Pump randomly stopped working...
  • Thread starter Thread starter GreatWhite
  • Start date Start date Jun 22, 2010
GreatWhite
232
Fairfield, PA
Jun 22, 2010
  • Jun 22, 2010
Anybody,
Ok, so I've had a ton of electrical issues with my '89 LX, but one really caught me off guard the other day.
I just put in a Optima Yellow Top battery, which is amazing (I had issues with batteries dieing in the past), so anyway... car runs, drives and operates completely normally now. No charging or not starting issues.
So I drove my car about an hour then shut it off at my apartment. Then I went back out about 15 minutes later, tried to start it, and the fuel pump didn't prime. Disconnected the battery, still nothing. I was frustrated, so I just went to bed and left the battery disconnected. Next morning, go out to start it, it fires right up and runs like nothing was wrong.
Is this just a sign of a switch going or what? The fuel pump is only about 5 years old and has only been run about 10-15k miles.
Any thoughts or things I should check first?
I just want to get this dang car reliable enough to drive more often. It sucks not wanting to drive it back you don't know if it will start one time or another. My DD Dodge Caliber sucks...haha
Thanks guys.
(P.S. I haven't been on here in about 2 years, so hello everybody!)
seedeezy
41
  • Jun 22, 2010
The fuel pump relay thats under your driver seat I would check first. Grab ahold of it when it is supposed to prime and see if it is doing its thing. I know the fuel pump isn't running but the relay may still be getting ground for 2 sec and allowing continuity through itself like its supposed to. Hopefully its not, and a fuel pump relay is where the issue is.
2000xp8
SN Certified Technician
Aug 8, 2003
8,058
1,643
194
NJ
Jun 22, 2010
  • Jun 22, 2010
Do check the relay first as suggested. I always had a spare relay in the glove box, you never knew when that thing was going to act up.
But i'd be mentally prepared to replace the pump.
Sometimes when a pump is on it's way out it won't work when hot, then it cools and it works again.
twistedwankel
200
Spring Hill, FL
Jun 23, 2010
  • Jun 23, 2010
+1 on this. I'm a bit surprised after 15 minutes it wouldn't even prime making me think more likely the relay or bad connection/ground as ususally a couple minutes is enough cooling time for at least a reprime. If your pump is noisy when priming (sick cow sound) or when you stand behind the car (constant drone) it's probably the pump going south. Clean your electrical connections if nothing else.
With your "ton of electrical issues" is your ignition switch okay? Did the starter spin or other things work when you turned the key?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 23, 2010
  • Jun 23, 2010
Fuel Pump Troubleshooting for 87-90 Mustangs
Clue – listen for the fuel pump to prime when you first turn the ignition switch on.
It should run for 2-5 seconds and shut off. This on and off again cycle helps to prevent
flooding the engine when cranking. To trick the fuel pump into running, find the ECC
test connector and jump the connector in the upper RH corner to ground.
If the fuse links are OK, you will have power to the pump. Check fuel pressure –
remove the cap from the Schrader valve behind the alternator and depress the
core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be
used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch
cars hide it under the plastic trim covering the driver's side taillight. Use the
voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built
before 92.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect
for fuel escaping while pump is running.
The electrical circuit for the fuel pump has two paths, a control path and a power
path.
The control path consists of the inertia switch, the computer, and the fuel pump
relay coil. It turns the fuel pump relay on or off under computer control. The
switched power (red wire) from the ECC relay goes to the inertia switch
(red/black wire) then from the inertia switch to the relay coil and then from the
relay coil to the computer (tan/ Lt green wire). The computer provides the ground
path to complete the circuit. This ground causes the relay coil to energize and
close the contacts for the power path. Keep in mind that you can have voltage
to all the right places, but the computer must provide a ground. If there is no
ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like
fuses, except they are pieces of wire and are made right into the wiring harness.
The feed wire from the fuse link (orange/ light blue wire) goes to the fuel pump
relay contacts. When the contacts close because the relay energizes, the power
flows through the contacts to the fuel pump (light pink/black wire). Notice that
pin 19 on the computer is the monitor to make sure the pump has power.
The fuel pump has a black wire that supplies the ground to complete the circuit.
Remember that the computer does not source any power to actuators, relays
or injectors, but provides the ground necessary to complete the circuit. That
means one side of the circuit will always be hot, and the other side will go to
ground or below 1 volt as the computer switches on that circuit.
Diagram courtesy of AutoZone
Now that you have the theory of how it works, it’s time to go digging.
Look for 12 volts at the Orange/Lt. Blue wire (power source for fuel pump relay).
No voltage or low voltage, bad fuse link, bad wiring, bad ignition switch or ignition
switch wiring or connections. There is a mystery connector somewhere under the
driver’s side kick panel, between the fuel pump relay and the fuse link.
Turn on the key and jumper the fuel pump test connector to ground as previously
described. Look for 12 volts at the Light Pink/Black wire (relay controlled power
for the fuel pump). No voltage there means that the relay has failed, or there is a
broken wire in the relay control circuit.
Check the Red/black wire, it should have 12 volts. No 12 volts there, either the
inertia switch is open or has no power to it. Check both sides of the inertia
switch: there should be power on the Red wire and Red/Black wire. Power on the
Red wire and not on the Red/Black wire means the inertia switch is open.
Make sure that the power is off the circuit before making any resistance checks.
If the circuit is powered up, your resistance measurements will be inaccurate.
You will have to drop the tank to inspect the pump power and ground connector
and the pump wiring chassis ground.
Pump wiring: Anytime the ignition switch is in the Run position and the test
point is jumpered to ground, there should be at least 12 volts present on the
black/pink wire. You should see less than 1 Ohm between the black wire(s)
and ground. The chassis ground is up near the spare tire shell. To get some
idea of what a good reading is, short the two meter leads together and
observe the reading. It should only be slightly higher when you measure
the black wire to ground resistance.
The Tan/Lt Green wire provides a ground path for the relay power. With the test
connector jumpered to ground, there should be less than .75 volts. Use a test
lamp with one side connected to battery power and the other side to the
Tan/Lt Green wire. The test light should glow brightly. No glow and you have a
broken wire or bad connection between the test connector and the relay. To test
the wiring from the computer, remove the passenger side kick panel and
disconnect the computer connector. It has a 10 MM bolt that holds it in place.
With the test lamp connected to power, jumper pin 22 to ground and the test
lamp should glow. No glow and the wiring between the computer and the fuel
pump relay is bad.
Computer: If you got this far and everything else checked out good, the computer is suspect.
Remove the test jumper from the ECC test connector located under the hood.
Probe computer pin 22 with a safety pin and ground it to chassis. Make sure the computer
and everything else is connected. Turn the ignition switch to the Run position and observe
the fuel pressure. The pump should run at full pressure.
If it doesn't, the wiring between pin 22 on the computer and the fuel pump relay is bad.
If it does run at full pressure, the computer may have failed.
Keep in mind that the computer only runs the fuel pump for about 2-3 seconds when you turn
the key to the Run position. This can sometimes fool you into thinking the computer has died.
Connect one lead of the test light to power and the other lead to computer pin 22 with a safety pin.
With the ignition switch Off, jumper the computer into self test mode like you are going to dump
the codes. Turn the ignition switch to the Run position. The light will flicker when the computer
does the self test routine. A flickering light is a good computer. No flickering light is a bad computer.
Fuel pump runs continuously: The fuel pump relay contacts are stuck together or the Tan/Lt Green wire
has shorted to ground. Remove the fuel pump relay from its socket. Then disconnect the computer and use
an ohmmeter to check out the resistance between the Tan/Lt Green wire and ground. You should see
more than 10 K Ohms (10,000 ohms) or an infinite open circuit. Be sure that the test connector isn’t
jumpered to ground.
If the wiring checks out good, then the computer is the likely culprit.
Prior to replacing the computer, check the computer power ground. The computer has its own
dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to
it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a
black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. You'll find it up
next to the starter solenoid where the wire goes into the wiring harness
If all of the checks have worked OK to this point, then the computer is bad. The
computers are very reliable and not prone to failure unless there has been
significant electrical trauma to the car. Things like lightning strikes and putting
the battery in backwards or connecting jumper cables backwards are about the
only thing that kills the computer.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
GreatWhite
232
Fairfield, PA
Jun 25, 2010
  • Jun 25, 2010
By ton of electrical issues, I was referring to my trunk mounted battery that would lose charge after say, two weeks of sitting with the battery connected. It's grounded, it's connected right, mechanic said it wasn't drawing anywhere when it was off... but it would still die, causing me so many headaches. My only guess was that since it was a conventional battery, the load starting the motor killed it after so long. But now with the Optima, it's amazing. Plus, while it's sitting at home for the time being, I have it all disconnected. So I should be good now on that.
(I don't daily drive it, which sucks, but the fact that I have had problems with the fuel pump doesn't make me want to start...)
With that said, I will check up on the relay, and like I said, I really don't think it's the pump. Does BBK make bad pumps? I bought the one that was a step up from the stocker when about six years ago and I haven't driven it more than maybe 20,000-25,000 miles... that enough to fry it?
Thanks for the replies guys.
2000xp8
Aug 8, 2003
8,058
1,643
194
NJ
Jun 25, 2010
  • Jun 25, 2010
BBK probaly just rebrands a walbro pump. Good quality.
But it's like any other electrical motor, some last longer than others and normally motors don't like to sit too long between uses.
First things first, see if the relay is clicking when the pump is not working.
If it is, basically the problem is either the wiring to the pump or the pump.
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
Fox 5.0 Mustang Tech Jul 22, 2026
