Well after having my pump go bad I found while checking the basics my fuel pump relay was warm to the touch after 1/2 run time. I have since replaced the bad pump with a 255 unit and fresh filter, replaced the connector for the relay and the relay as well. Now after a good drive I have found the relay head ( for lack of a better word) is warm still! The wiring is not heating up and the connector portion where the spade conncetors are located (bottom..again lack of better word) is not warm at all...just the top portion of the relay it's self. The car is working perfectly, charging system is excellent and the pump is quiet as can be and primes perfectly. It seems to take a while for the heat to build on the relay...and is only warm, not hot so I'm kind of at a loss as the if I should even continue to worry about it any more.
