Fuel pump relay??
It might be the fuel pump relay if the car doesnt start. blksn955.o is right it is in the ccrm, the ccrm has a bunch of relays in it and the fuel pump relay is one of them. The crappy thing it is serviced as a unit so it will run you around $120
What does the ccrm look like? I purchased a fuel pump relay from my work (advance auto parts) hoping this would be the easy fix. I looked around the radiator for this ccrm thing but I'm not sure what I'm looking for exactly. This is on a 1995 GT. The GT is my daily driver and it has been down awhile...and often. My camaro is more reliable and it is pretty built. Carb with no choke and it still starts in 40 degree weather...I need help with this mustang...its getting cold and my camaro doesn't have heat! Help.
I read some other posts and people seemed to think my problems were from the pickup in the distributor. So I bought the pickup and then went to a buddies and used his press to take it apart and put the new one in. Went ahead and installed a new coil to. WALLA its fixed.
Dude, tell me you're still on here....i need some help reference this same thing
