Fuel Pump Relay
  • Thread starter Thread starter mr_bird
  • Start date Start date Apr 29, 2006
M
mr_bird
18
  • Apr 29, 2006
I need to drain the fuel from my fuel rails on my 1993 mustang GT, I've been told the best way to do this is to disconnect the fuel pump relay and let the engine use all the fuel in its lines. There's just one problem i cant seem to find the fuel pump relay. The owners manual isnt too specific about it, and I just cant seem to find it, just wonderijng if anyone can tell me where it is, or knows of a better way to drain the fuel rails, thanks for the help
D
Doc90
38
texas
Apr 29, 2006
  • Apr 29, 2006
mr bird your fuel pump relay should be under your driver seat
M
mr_bird
18
  • Apr 29, 2006
There is no fuel pump relay underneath my driver seat, i have started the car a few times and think i have located it near the intake tubing, there are two black relays underneath my intake pipe that click when i turn the ignition on. Could one of these possibly the fuel pump relay?
G
gt90stang
568
  • Apr 29, 2006
You don't need to drain the fuel rails with the stock rails. Just release any pressure with the Schrader valve into a couple of paper towels...you won't get much fuel. Then when you disconnect the locking fittings catch the fuel in a couple of paper towels..again you won't get much fuel. Throw the paper towels in the trash outside away from open flames and sparks, it will evaporate.
Don
HISSIN50
34
129
Apr 29, 2006
  • Apr 29, 2006
Yes, on your '93, the FP relay is next to the WOT relay under the hood.
Though I havent done it, I suppose opening the inertia switch would work.
Don's method is how I generally do it (I'm too lazy to fart around with pulling relays, etc).
Good luck.
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
U
No fuel pump relay in harness
  • Uli661
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
Uli661
U
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
1990 foxbody 5.0 fuel system.
  • staceyj
  • Nov 28, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Mustang5L5
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
