I believe one is inside the CCRM, and I'm not sure if there is another. If there is something wrong with the relay in the CCRM the whole module has to be replaced.
I know little on this matter, but maybe someone else can help more.
Does anyone know if there is a way to check the ccrm to determine if the relays inside are bad?. Also is this a ford replacement item only?. If so does anyone know how much it is to replace?. Thanks
I got my replacement at a junkyard for like $20, works perfectly, as for checking it idk, you'd have to figure out what pins controlled it and apply a voltage to it and see if its working.
