Fuel Pump Removal
Trying to get my fuel pump out of the gas tank, but the fuel pump housing is not under the gas tank hole and I can’t get the thing out of the tank. Hoping someone has some ideas how much force I can put against the holder that‘s attached to the bottom of the tank.
Pretty sure you have to drop the tank to get to the fuel pump and sending unit, at least that is what I had to do when I changed mine. It is a pain. I would think it would be tough to gain enough clearance to remove the unit if the tank is still hanging on the straps and various lines.
What year and model is the car? The pump style changes mid-1998, so for a more detailed answer really need to know if this is a 96-98 with the return style fuel system, or a 99-04 with the returnless style.
Would also help to know what the "tank hole" is that you are referring to. There are a few holes in the tank
