Fuel Pump Screaming
  • Thread starter Thread starter Tim Sisk
  • Start date Start date Feb 28, 2016
T
Tim Sisk
21
  • Feb 28, 2016
My car has a bbk 255lph, it's been parked for a good while tried to run it today and the fuel pump is very very loud way louder than usual my pressure is set at 38 lbs and is running 60 lbs the gas that was in it which about 2 gallon I put some fresh gas in it and still didn't fix the problem pulled the filter and it was nasty couldn't hardly blow threw it should I just change the filter or just go ahead and pull the tank? ??
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Feb 28, 2016
  • Feb 28, 2016
I would disconnect the line from the tank to the fuel rail and pump out all the fuel in the tank into a gas container, then drop and clean the tank. You don't want that crap getting into your rail or injectors. Then I would put a new sock on the pump, new filter, and then when you fill the tank dump a bottle of techron in it.
Reactions: jrichker
MFE92
1,094
373
124
Phoenix
Feb 28, 2016
  • Feb 28, 2016
The pump is dying.
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
D
Fox 88 foxbody no power to red and black wire at fuel pump relay
  • drod88
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
Mcmahst
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
